Xjs 12 rough idle
Old Feb 14, 2015 | 08:09 PM
Jag 31410's Avatar
Default Xjs 12 rough idle
I am getting a ff36 check engine code. In addition, the engine is running very rough to the point it almost stalls. I am not sure where I should start checking. Any help is appreciated.
Old Feb 14, 2015 | 09:05 PM
superchargedtr6's Avatar
I just googled it, and found uneven heating on O2 sensor, B bank.
Old Feb 15, 2015 | 06:42 AM
Jag 31410's Avatar
Thanks for the help. I'll give it a try and hopefully that will do the trick.
Old Feb 15, 2015 | 03:31 PM
sidescrollin's Avatar
If you have a IR thermometer, check the temps on the cat to see if its dead. Hopefully your o2 sensor is just bad. I want to say the rear of the cat should be no more than 150 degrees or so hotter than the front of it. Maybe its getting too much fuel from a bad o2(or other issue) or maybe the cat itself is bad. You can also try to do a quick check between the pipes, if there is a lack of pressure at the pipe with the suspect cat, it could be collapsed.
Old Feb 16, 2015 | 02:17 PM
Jag 31410's Avatar
I checked the temp and it is about 150 degrees different. It was running a little rough but it was not very noticeable until it warmed up and the idle dropped and it became more noticable. After it ran for a few minutes I turned it off and it would not restart. The engine turns over and it stutters but won't start.
Old Feb 17, 2015 | 01:54 AM
Greg in France's Avatar
Marelli failure on one bank?
Greg
Old Feb 17, 2015 | 06:45 AM
Jag 31410's Avatar
What is the best way to begin checking the marreli system?
Old Feb 17, 2015 | 08:16 AM
bhamilton's Avatar
I applaud you guys for answering the same questions over and over without getting annoyed.
Old Feb 17, 2015 | 09:35 AM
Safari's Avatar
Every one of us was a "newbie" at one time. We all remember how it was when we first looked for help with our car.
I still have a lot to learn and many questions to come but I'm more than happy to help the new folks with whatever knowledge I have acquired.
I think appreciation for the XJS is growing so I expect many more new people here in the future.
Welcome to all!!
Mark
Old Feb 17, 2015 | 04:38 PM
Jag 31410's Avatar
I appreciate the help. That's what sets this site apart from the others. People are willing to help without belittling others.
Old Feb 20, 2015 | 09:49 PM
Jag 31410's Avatar
So I bought a new cap and rotor. I keep seeing things about modifications to make, grinding things down and so forth. Are these things necessary or just in case type of things?
Old Feb 20, 2015 | 10:24 PM
Safari's Avatar
If you have the Marelli ignition then you definitely should make the modification. The mod nearly eliminates cat converter fires due to the loss of ignition on the right side of the engine.
Here is a link to how its done;
https://www.jaguarforums.com/forum/x...photos-135024/
Mark
Bcrary3
Feb 21, 2023 04:29 AM
Rivguy
Dec 4, 2020 07:55 AM
scooternva
19
Oct 27, 2015 02:14 PM
Mac Allan
Oct 27, 2015 04:49 AM
Bowman
Sep 3, 2015 03:17 PM
