XJS - Fault Code FF37
Old Jul 19, 2016 | 12:08 PM
whitmcfarlin's Avatar
Default XJS - Fault Code FF37
My '94 XJS won't start unless I short the terminals on the starter solenoid. I get the fault code FF37. What does that mean?
thanks Whit
Old Jul 19, 2016 | 01:54 PM
Whit,
I've moved your question from General Tech Help to XJS forum. This is the place to post technical questions about your model.
Old Jul 19, 2016 | 03:22 PM
Paul_59's Avatar
Banned
thanks Whit
FF37 not listed on V12; assuming you have a 4.0 L engine it is referred to as a faulty EGR (exhaust gas recirculation) solenoid.
Sorry I don't have any more knowledge about this engine or faults.
Hopefully someone else will reply
Old Jul 20, 2016 | 03:54 PM
xjsrookie's Avatar
I believe FF37 is an Air Pump Fault on the V12.
Old Jul 21, 2016 | 05:17 AM
Default XJS fault FF37
XJSrookie
My XJS is a 4.0L...wonder if it's the same fault code for both?
Thanks for the response...Whit
Old Jul 26, 2016 | 12:05 PM
Paul_59's Avatar
Banned
On V12 with Lucas / Marelli ecu
Faulty air injection operation is FF 67.
FF37 isn't listed in any Jaguar documents I have regarding engine management
Old Sep 8, 2019 | 08:46 AM
Josh Knight's Avatar
Default Photos of EGR
Just wondering if anyone has a link to a photo showing the EGR sensor on a 92-96 XJS 4L 6 Cyl. I have just got an FF37 code. Wanted to clean terminals before trying to replace.
94’ 4L 6 Cyl
XJS
Old Sep 8, 2019 | 09:52 AM
motorcarman's Avatar
Many years ago I uploaded S91_AJ6 4.0 Engine Management.pdf to a few Jaguar related sites. It will explain EVERYTHING you ever wanted to know about the AJ6 4.0 engine management.
The file is over 13mb so I cannot upload it to this post.
Just search S91_AJ6 4.0 Engine Management.pdf and you will find it somewhere on the internet.
Gus will have it on his site.
bob
Old Sep 8, 2019 | 01:53 PM
bob
thank you, that was very helpful... got the problem sorted for now!
Old Sep 8, 2019 | 04:32 PM
JayJagJay's Avatar
Ok! Great....
What was the problem,,,,, for the next guy...?
Old Sep 8, 2019 | 06:31 PM
An FF37 fault code is identified as a EGR Circuit fault (exhaust gas return). This can be caused by a number of things, but primarily it is the EGR Valve or EGR solenoid. The Valve is on the right hand side of the cylinders, the solenoid is on the left rear of cylinders. Likely the cause of the fault is the connectors in the solenoid are grimy, or the solenoid itself is faulty.
I cleaned the connectors, disconnected the battery, reconnected to reset the fault. All seems to be running well again.
designation
May 6, 2025 11:07 AM
Stevie b
Apr 30, 2017 06:36 AM
coug66
16
May 28, 2016 06:35 PM
Nov 20, 2006 10:55 PM
