You've got to be kidding me...
Old Sep 27, 2013 | 07:01 PM
J_C_R's Avatar
Default You've got to be kidding me...
I'm replacing the sealed beams on my '87 XJ-S V12 with some euro lights, so I've got the front jacked up to run the wiring and do some other stuff.
One of the "other stuff" things is to put a front license plate on. Imagine my surprise when I reach behind the front bumper and find that there are NO HOLES in the back of the bumper with which to reach in and tighten the license plate nuts.
Of course this is all venting...but just out of curiosity, how did Jaguar intend for someone to mount a front license plate without either removing the bumper, drilling holes into the back of it, or using really big/strong sheet metal screws?
Or...am I missing something really obvious???
Thanks,
John
1987 XJ-S V12, 62,000 miles
Old Sep 27, 2013 | 07:29 PM
Katoh's Avatar
Sorry have to laugh, when I bought mine the front and back plates were held on by Tech-Screws just screwed into the plastic! Wow no expense spared there.
I just left it as is. Next year some time my car will be re-sprayed and once its exterior has being stripped Ill use Stainless nuts and bolts to fit the plates while everything is off.
Good Luck
Old Sep 28, 2013 | 07:35 AM
AllanG's Avatar
Yes you have to drill holes in the bumper. Jag supplied a front license plate bracket/reinforcement with every car in the US. It was dealer fitted depending on local state regulations.
This diagram shows the part (#29)
Cheers,
Allan
Old Sep 28, 2013 | 02:43 PM
J_C_R's Avatar
Interesting, thanks for sharing it.
We're not required to have front plates in Indiana, so maybe it is from "here" and the dealer didn't bother/need to mount it. In a way though I'm still missing the point. My bumper does have the two slotted holes that match up with the top holes on a license plate, but even if the reinforcement plate were installed, there is still no way to get behind it to undo the top bolts, unless maybe the reinforcement plate came with plastic "nuts" permanently mounted in it (there is a name for them, but I don't know it) and using plastic bolts or screws was how the plate was supposed to be mounted?
If anyone has a photo of this arrangement I'd enjoy seeing it.
Thanks!
John
Old Sep 29, 2013 | 11:13 AM
Sarc's Avatar
@John
Yes, it's not the best design by any means.
I made up some little metal "flaps" or "ears" and, when used with long thin bolts allow me to hook my plate on. The flaps go between the metal part of the bumper and the rubber outside part.
Hopefully these pictures help explain what I'm talking about
My car didn't have a front plate on it when I got it so I cobbled this together myself.
Has been fine for the past 3 years
Attached Thumbnails You've got to be kidding me...-sarc-4188-albums-posts-2-7409-picture-20130929-091653-20665.jpg   You've got to be kidding me...-sarc-4188-albums-posts-2-7409-picture-20130929-091809-20666.jpg   You've got to be kidding me...-sarc-4188-albums-posts-2-7409-picture-20130929-091832-20667.jpg
Old Sep 29, 2013 | 01:53 PM
plums's Avatar
There are nylon licence plate bolt sets that have square nuts intended to lock into slots on some cars with that provision. With those, the nuts are inserted, the plate lined up, and the bolts screwed in from the front without need to access the rear. They also don't rust.
Old Sep 29, 2013 | 04:46 PM
Vee's Avatar
Vee
I bought a license plate holder from Advance Auto and used nylon zip ties to hang the holder through the holes in the lower spoiler. You couldn't see the zip ties and I thought the front license plate looked better tucked under the front bumper, not tacked on to the bumper itself.
Old Sep 29, 2013 | 07:41 PM
J_C_R's Avatar
Thanks guys. I did pick up a couple of nylon "nuts" at the store today, so I'll give those a try before I start drilling through the back of the bumper. Lacking success there I'll give Sarc's idea a go.
Thanks!
John
Old Sep 29, 2013 | 09:21 PM
Doug's Avatar
Worth a try but I recall that the commonly available nylon license plate nuts are too big for the existing slots.
FWIW, I used sheet metal screws that that were *just* the right size to bite into the slots.
jagtoes
Apr 22, 2016 07:37 AM
MrWhite
Oct 1, 2015 01:43 AM
sg997tt
Sep 29, 2015 08:13 AM
sg997tt
Canada
Sep 27, 2015 02:40 PM
