2007 XK ashtray cover
Old Aug 5, 2024 | 11:16 AM
pbcs004's Avatar
Default 2007 XK ashtray cover
Spring on the ash tray cover is broken on my 2007 XK. Is it a big job to repair it.
Old Aug 5, 2024 | 01:09 PM
Cee Jay's Avatar
More-so than the 2010 and later as the shifter knob must be removed so the trim panels can be CAREFULLY removed with a suitable trim tool.
There are a few good threads about shifter knobs and console trim removal, and at least one on the ashtray lid.
Use the Search! It's usually helpful.
Old Aug 5, 2024 | 02:32 PM
kj07xk's Avatar
That’s not true Cee Jay, the shifter does not need to be removed.
The console does need to be removed to get to the ashtray components, did that some number of years ago to fix mine. Best to see the steps in the workshop manual, rather than trying to remember and repeat them here.
Old Aug 5, 2024 | 03:46 PM
Cee Jay's Avatar
I don't 'remember' anything as I've never done it, especially on a knobby shifter car. Makes sense to me to have the shifter surround removed instead of working around it. That'd make it easier to remove everything else below that instead of fishing stuff around through holes and such.
If'n I had to do it, I'd certainly remove Mr. Knobby.
Old Aug 5, 2024 | 04:44 PM
kj07xk's Avatar
You have to lift out the center console, and the ashtray comes with it. The gear shift unit stays put (I think you need to shift the gear lever to N in order to provide clearance to lift out the console).
Krisprz
Sep 22, 2025 12:21 PM
rez1only1
Apr 11, 2025 08:00 PM
ed duffy
Oct 31, 2019 01:32 PM
Keith Coe
Jul 21, 2016 07:36 AM
