2007 xk battery tray
Old Aug 19, 2018 | 09:30 AM
mrfixit99's Avatar
Default 2007 xk battery tray
The battery needs to be replaced in my 2007 xk convertible. The old battery leaked all over the battery tray and the sheet metal underneath it, and there is significant corrosion. I would like to remove the tray so I can do a complete clean-up job. It seems to be riveted in place. Is that the case? Should I just leave the tray in place and clean up the best I can?
Old Aug 19, 2018 | 11:19 AM
Ranchero50's Avatar
Yeah, mine was the same way. Lots of baking soda and water. There's a plug under the spare tire that once popped out will allow it to drain.
Old Aug 19, 2018 | 12:30 PM
Sean W's Avatar
^^^^ +1 - then follow it up with a rubberized paint or something like Plastidip to prevent further corrosion.
Old Aug 19, 2018 | 05:52 PM
mrfixit99's Avatar
Thanks to Ranchero50 and Sean W. I have some plasticote stuff and brushed it all over the battery tray area after I cleaned up the corrosion the best I could. I hope the new battery won't repeat this problem.
Old Aug 19, 2018 | 08:16 PM
Stuart S's Avatar
Make sure that your new battery is properly vented to the outside. Otherwise, the hydrogen gas that occurs during charging will produce corrosive vapor in your battery compartment and damage your car. And possibly explode.
Old Aug 20, 2018 | 07:44 AM
mrfixit99's Avatar
Stuart, thanks for the tip about venting. The vent hose was attached when I removed the old battery, but I'll check and make sure the hose isn't kinked or plugged. Now I'm wondering if that had anything to do with the extensive corrosion on and around the battery tray.
Old Aug 20, 2018 | 11:52 AM
Ranchero50's Avatar
The PO's of my poor car kept the rear panel off and a 15 amp charger hooked up all the time versus just replace the battery... Looked like old soda had been poured across the top from it overflowing when overcharged.
With the new battery and occasional topping off with a tender the battery stays new looking. I sprayed LPS3 on the corroded bits to keep them from getting worse.
Old Aug 20, 2018 | 04:12 PM
Queen and Country's Avatar
This reason alone makes AGM battery the only sensible solution for the XK.
Old Aug 21, 2018 | 09:22 AM
mrfixit99's Avatar
Thanks to all for the insights and histories. I got a new battery at a pretty decent price ($130) but it was coated with dust and looked like it had been sitting for a long time. It has a label on it which could be the date code (31/16) from the manufacturer in Germany. I hope that doesn't mean it was made during the 31st week on 2016. But if it doesn't hold up, at least is has a 36 month full replacement warranty. I guess I'd be willing to go thru the hassle of replacing it again if it failed within that time. I will maintain it as necessary, with an onboard Schumacher 1.5 amp charger.
kenbowen
Jun 2, 2020 11:30 PM
CyJag
38
Apr 23, 2017 10:58 PM
gijsen
48
Nov 18, 2016 12:29 PM
sjuraud
Aug 28, 2010 02:11 PM
ancientsanskrit
Aug 1, 2007 11:15 AM
