Aluminium Key Blanks
Emergency aluminum key blades on eBay are inexpensive Chinese copies. Fortunately, you have an OEM blade so you can make sure that the shape of the blank is exactly the same as the OEM blade so it fits properly in the fob. The big expense is having that blank laser cut on both sides by a locksmith. Because the blanks are so cheap, I'd buy one or two extras in case the locksmith buggers one and it doesn't work.
Just my advice based on my experience.
XK Steve (01-18-2018)
I took two of the Ebay chinese aluminium (???) blanks to the locksmith who tried to cut them after he verified the code for the original. The key basically melted - probably made out of the same material that is being used for architectural facings on buildings and responsible for many fires around the world including here in Melbourne. Only thing he could do was use a Ford blank which works, but won't fit the fob of course. Laser cutting a new blank seems OK but how do you put in the notch for the clip? The 44.00 charge is confirmed by the way!! The car came with three fobs but only one key.
I doubt anybody is using a laser to cut the keys. They may use a laser to trace the cutting path from the original but not cut the key. If the key "melted" my guess is the cutter was dull and smeared the soft aluminum instead of cutting it.
Since most keys are brass, I'm pretty sure most cutting machines have parameters for that, cutter speed and grind grit/TPI. Cutting alumin(i)um needs slower speeds and less 'cut'. The guy who cut my (now lost) key mucked up HIS machine also, therefore wouldn't cut the second. Now I have zero, key-code-in-hand (which doesn't reference now), and zero keys.
Received 1,897 Likes
Cee Jay (01-19-2018)
BonnieTX70
01-27-2017 06:30 PM
