2007 xk x150 cjb (bcm)
Old Apr 7, 2025 | 08:51 AM
EdwardinTexas's Avatar
Default 2007 xk x150 cjb (bcm)
Has anyone re-flashed an X150 Central Junction Box, also called a BCM?
Old Apr 7, 2025 | 10:28 AM
guy's Avatar
guy
The actual acronym is.
In your particular car, there is no BCM.
Cheers.
Old Apr 7, 2025 | 11:12 AM
xalty's Avatar
Cheers.
FSJB, CJB and BCM are used interchangeably. same way FEM is also GECM on older cars
Old Apr 14, 2025 | 03:36 PM
guy's Avatar
guy
FWIW, a Central Junction Box is a very different device from a Battery Control Module. If anyone is using these terms interchangeably, they are wrong.
The complete list of appropriate acronyms for your car is found in the Workshop manual.
Old Apr 14, 2025 | 03:54 PM
Sean W's Avatar
In this case, BCM refers to body control module, aka CJB
Old Apr 14, 2025 | 04:44 PM
guy's Avatar
guy
From the workshop manuals .
File Type: pdf
File Type: pdf
Old Apr 15, 2025 | 09:17 AM
Sean W's Avatar
Old Apr 15, 2025 | 10:58 AM
xalty's Avatar
Body Control Module, Front Smart Junction Box, Central Junction Box are all interchangeable as i've said. When you work across multiple years of vehicles you end up just using the most common term. Ford itself ended dropping the Smart Junction Box term like a rock and going to BCM as well in 2010s.
Old Apr 18, 2025 | 06:03 PM
Tech_JLR's Avatar
Yes it can be flashed, what is the issue. Are you not able to flash it ?
rez1only1
Apr 11, 2025 08:00 PM
MFoncerrada8
Oct 17, 2024 03:08 PM
mosesbotbol
Jan 27, 2022 03:22 PM
WldCat
Aug 12, 2020 11:55 PM
robbing
Oct 1, 2015 11:24 AM
