2008 waterpump
Old Oct 30, 2024 | 07:12 PM
wymjym's Avatar
Default 2008 waterpump
Pulled the pump, plastic impeller...is this original type?
wj
Old Oct 31, 2024 | 12:21 AM
kj07xk's Avatar
Think so.
Old Oct 31, 2024 | 12:48 PM
Sean W's Avatar
Agree - no experience personally, but plastic impellers have been common in cars for a while now. @panthera999 should be able to weigh in as he recently replaced his.
Old Oct 31, 2024 | 01:07 PM
kj07xk's Avatar
I recall reading a thread here (a few years ago) where a plastic impeller blade had broke off and was blocking coolant flow.
Old Nov 1, 2024 | 08:46 AM
wymjym's Avatar
I ordered hoses, gaskets and water pump...then awoke this morning questioning my decision to opt for the ac/delco that has a cast iron impeller. Is there any issue using cast iron with aluminum?
wj
Old Nov 1, 2024 | 11:46 AM
Stuart S's Avatar
subscribed
Old Nov 1, 2024 | 02:43 PM
Sean W's Avatar
wj
cast iron heads on aluminum blocks have been around for years and you have to account for corrosion when mating the two metals. The impeller isn't in contact with the aluminum. I see no issue.
Old Nov 2, 2024 | 08:18 AM
wymjym's Avatar
wj
Henriklundin89
XJ40 ( XJ81 )
Oct 8, 2024 01:22 AM
aquifer
Jul 21, 2021 11:42 PM
Andreas Schmieg
Mar 18, 2018 01:51 PM
Jimmy 68
Sep 4, 2014 02:52 PM
Dan R
Jan 26, 2011 08:23 AM
