2010 XKR front end noise and shake issue
Old Aug 3, 2019 | 03:19 PM
EnRoute30's Avatar
Default 2010 XKR front end noise and shake issue
So my 2010 XKR recently developed a pretty significant front end noise (classic whop whop whop whop) and front end/steering wheel shake. I initially thought my front passenger rim was bent, causing these issues, which I’ve experienced before with a back rim and this seemed like it was doing the same thing. I was in the market for new wheels, so I replaced all four rims/tires with a set of aftermarket TSW’s. Same offset, only the rear rims are a little wider. After having all 4 tires balanced and mounted, the noise and shake is still there. It’s worse and lower rpms, while breaking, and while going around curves. You can feel it through the entire front end, tho it seems to be coming from the front passenger side mostly. And it’s loud enough to be extremely obnoxious while driving unless the radio is up. It’s a constant noise and shake, and I’m looking for ideas to get this taken care of. I’m almost nervous to drive it in fear it may do more damage, but being my only transportation at the time, I kind of have to. So any help getting this figured out is greatly appreciated. I have not had it aligned in about 1.5yrs, it jus seems like more noise and vibration then that would cause, but I guess it could be anything at this point. Thanks
Old Aug 3, 2019 | 04:29 PM
ralphwg's Avatar
How many miles on your XKR? There are several threads on the forum dealing with bushings and motor mounts. Failure of either or both could cause what you are experiencing.
Old Aug 3, 2019 | 04:36 PM
EnRoute30's Avatar
It has 67k miles on it.
Old Aug 3, 2019 | 10:14 PM
Sean W's Avatar
A bit difficult to diagnose via forum. Are you intending to do the work yourself? Have you taken it to a shop?
Old Aug 3, 2019 | 11:02 PM
EnRoute30's Avatar
I haven’t taken it anywhere yet, and yes I was going to see if I could fix it myself. I did find a ball joint nut backed about halfway off, tightened it all the way back down, but still no change
Old Aug 4, 2019 | 04:01 AM
SteveSal's Avatar
That could be awfully dangerous, if you have found a nut undone on the suspension. Get it off the ground and go all over every connection on the suspension and steering, checking fasteners and looking for play in each. Use a bar or a big screw driver to see if there is movement.
Old Aug 4, 2019 | 01:23 PM
EnRoute30's Avatar
This is the bushing I found in bad shape on the passenger side
And this is obviously the nut I found backed off on the passenger side as well.
Old Aug 4, 2019 | 01:54 PM
jagtoes's Avatar
If the top picture is the upper A frame ball joint you are lucky so far. It is shot and will either break or separate from the socket. I suspect that what is causing the noise and the vibration may have caused the lower nut to come loose. Don't drive it until it is fixed. Check all of the joints and replace suspect ones.
Old Aug 4, 2019 | 05:57 PM
EnRoute30's Avatar
From what I’m seeing so far the upper ball joint and arm are all one piece. So that whole section will have to be replaced? You can’t just replace the upper ball joint itself.
Old Aug 4, 2019 | 08:00 PM
Sean W's Avatar
Correct, but the upper control arms can be had for cheap. S-Type, Lincoln LS, Thunderbird, XJ all share the same part. The 2010 guys will have to check me but I think the part hasn't changed from the earlier models like mine. I could be wrong:
https://www.ebay.com/itm/2PCS-Front-...S/272301201155
Old Aug 4, 2019 | 10:21 PM
Cee Jay's Avatar
.... or get the ones that list the 2010...
https://www.ebay.com/itm/Beck-Arnley...ry!84037!US!-1
Old Aug 5, 2019 | 03:42 AM
DannyJ's Avatar
You should check first if the ball joint is in good condition
Usually the rubber boot is teared off and can be replaced without removing the arm
Old Aug 5, 2019 | 08:28 AM
EnRoute30's Avatar
How is this done precisely??? Thanks
Old Aug 5, 2019 | 09:52 AM
Sean W's Avatar
Fairly easy. There isn't really a good place to put leverage on the upper joint though. With the wheel on jack the car up and put it on jack stands. Grab the tire at its axis (12 and 6 o'clock) and rock it. There should be no play. If you hear noise/ play from the upper, you have a bad ball joint. Looking at yours, if it's me, I'm replacing it.
On the lower you can remove the wheel and place a pry bar or screwdriver between the joint and the knuckle and look for play.
Old Sep 6, 2019 | 07:54 AM
EnRoute30's Avatar
Just an update, replaced ball joint and wheel bearing, and the shake/noise is gone.
sweeper
Jan 11, 2022 06:13 PM
JayJagJay
Feb 4, 2018 08:03 AM
Leo XJ8
Aug 9, 2014 02:55 PM
Bkny85
Apr 1, 2014 02:03 PM
mrrevas
Mar 4, 2011 04:42 PM
