2011 XKR Key Fob Woes....
Old Jan 31, 2018 | 11:33 PM
pita's Avatar
Default 2011 XKR Key Fob Woes....
Can someone help with a 2011 XKR key fob. I have two, one stopped working. The other seems ok, but the battery didn't last very long the first time I changed it. What is their life span? i don't even drive it daily.
Also the little spring that pops the key out has become bent...very fragile buggers!
Old Feb 1, 2018 | 02:55 AM
u102768's Avatar
If you need to replace the spring search for C2P15137. There are a few options on EBAY or your local dealer may be able to supply one reasonably cheaply.
The battery should last for quite a few months if not years but there are a lot of cheap/poor batteries for sale so I would try a different brand.
Old Feb 1, 2018 | 03:13 AM
The vehicle should warn when the smartkey battery needs replacing displaying SMART KEY BATTERY LOW in the message centre.
I always replace the batteries immediately with a new (to me) Jaguar and use premium CR2032 batteries. I kept my last XK for four years and the smartkey batteries never needed replacing in that time.
There was an issue with early smartkeys. The rear cover didn't put sufficient pressure on the battery to ensure good contact and the smartkey could fail to function. A later re-design of the cover resolved this. Replacement covers (or full repair kits) are available from Jaguar and are also listed by some dubious Chinese sources on ebay. The genuine rear cover has Jaguar and the logo embossed. Copies generally don't.
Old Feb 1, 2018 | 05:29 AM
Someb's Avatar
Perhaps this helps
https://nl.aliexpress.com/item/OkeyT...841140139.html
Only the cover without battery and chip.
Grtz
Ben
Old Feb 1, 2018 | 02:00 PM
Originally Posted by Someb
Perhaps this helps. .....
That's one of those Chinese copies I mentioned in post #3.
Old Feb 2, 2018 | 05:03 AM
cal2010XKR's Avatar
Have a 2010XKR one key don't work is there is place you can send they them for refab. What does a new one cost
Old Feb 2, 2018 | 05:27 AM
Welcome to the forum cal2010XKR,
Here in the UK, a new replacement smartkey is 170 UKP ($240) from Jaguar. Parts prices are usually higher in the US and it could be a lot more.
Repair is only half the solution. Unlike remote fobs on earlier models which can be DIY programmed by an owner, the smartkey has to be paired with the vehicle using dealer level diagnostics.
Old Feb 2, 2018 | 06:32 AM
Stuart S's Avatar
pita,
Read this old thread for important information about the Smartkey fob:
https://www.jaguarforums.com/forum/x...cement-117974/
Welcome to the Forum. Hope you enjoy your new ride! There's lots of information and helpful owners here. Learn to use the Search function since many questions have already been asked and answered.
Stuart
Old Feb 2, 2018 | 09:01 AM
davchr's Avatar
I have found a large variance in the life of the remote batteries. I am at two plus years on the batteries for my XJ. The recent replacement batteries for both remotes for my XK lasted less than two weeks. I don't know if they were old or just lousy but they did not last.
Old Feb 2, 2018 | 09:17 AM
Tervuren's Avatar
I know I've replaced my batteries at least twice in two years and three months.
Old Feb 2, 2018 | 10:43 PM
ralphwg's Avatar
I have found that the key fob batteries generally last about two years and you get a warning in the center of gauge pack right in front of the driver.
Old Feb 3, 2018 | 06:53 AM
jagtoes's Avatar
I would also think it is dependent on usage. I have 2 fob that I got with the car. I use one as my primary unit and the other is put away with the rest of my 2nd keys. I replaced both batteries when I got the car in 2014. I have put around 14,000 miles on the car and early last year I got the low key warning. I replaced that battery but not the 2nd key. Now recently I purchased a TPMS tester and it has a key fob test function. So I checked each key and it showed 80% on my primary key and 95% on my 2nd key which is not used. Now I don't know how good the test reader is but it does show a difference. So now I'll do a yearly test when I get my annual car inspection and replace as necessary.
simon3166
Dec 3, 2023 12:18 PM
tag1000
Feb 3, 2018 03:55 AM
Jimmy 68
Oct 31, 2016 10:19 AM
duanelj
May 5, 2014 08:22 AM
