2012 Daytime Running Lights
Old Mar 10, 2018 | 08:24 AM
IanXF's Avatar
Default 2012 Daytime Running Lights
Just Traded my 08 XK for A 2012 XK as I was going over the car I noticed that the DRLs are only on when the headlights are on I read the owners manual it says Canadian models will go on only in drive with the e brake off I’m in US ,mine are not on during the day I thought they were supposed to be on all the time Can anyone tell me if that’s the case
Thanks Ian
Old Mar 10, 2018 | 08:27 AM
davchr's Avatar
The DRLs on my 12 XK are on all the time.
Old Mar 10, 2018 | 08:31 AM
IanXF's Avatar
Thanks thought so
Old Mar 10, 2018 | 09:57 AM
jagtoes's Avatar
Mine are on all the time too.
Old Mar 10, 2018 | 05:18 PM
ralphwg's Avatar
Mine are on all the time. There is a setting in one of the computer modules that can be modified by a dealer. Perhaps an indie with all of the appropriate computer equipment can modify the settings. If not you will have to go to a dealer to have them check out the drl's
Old Mar 10, 2018 | 06:42 PM
Originally Posted by IanXF
..... I’m in US ,mine are not on during the day I thought they were supposed to be on all the time Can anyone tell me if that’s the case.
Daytime
Running
Lamps
ON - regardless of where you are.
Old Mar 10, 2018 | 07:29 PM
IanXF's Avatar
I’m wondering if there’s a relay that may have gone bad does anyone have the location of which relay it could be I know were they all are it’s just I haven’t found a description of which relay controls what function
Old Mar 12, 2018 | 09:59 AM
For 2012MY onwards, the DLR are controlled and protected through the CJB (Central Junction Box).
Unlike earlier models, Jaguar don't publish full details of relays in the Owner's Handbook and even the Workshop Manual doesn't have a single, full list.
The Electrical Guide has also gone from being a clearly indexed document to the equivalent of doing a 5000 piece jigsaw without the benefit of the picture on the box.
Your USA specification DLR are different to both Canadian specification and my European specification. The following description should help identify how your DLR should operate.
The DRL operate automatically when a gear is selected after starting the engine. They then remain on until the ignition is switched off, or side lamps or headlamps are selected on. On USA vehicles, the DRL also go off if the transmission is selected to P or N and the parking brake is applied. While a turn signal indicator is operational, the daytime running lamp on that side of the vehicle either reduces in intensity, to the side lamp level (all except USA), or goes off (USA).
Old Mar 12, 2018 | 11:30 AM
IanXF's Avatar
Bringing it in to the dealer Wednesday for them to check it out plus a few more small items I will post the findings
Thanks to all
Old Mar 12, 2018 | 11:40 AM
Mufc's Avatar
When you first start the car in Park they are off. Once you select reverse or drive they tun on
Old Mar 12, 2018 | 12:46 PM
IanXF's Avatar
They are always off drive park or neutral brake on or off only on when headlight switch is on
Old Mar 12, 2018 | 01:29 PM
Mufc's Avatar
Probably had some E-bay parts fitted to it that have not been coded properly. Any sign of accident damage
Old Mar 12, 2018 | 01:33 PM
IanXF's Avatar
Had a clean carfax I went through the front end and saw no signs of a respray or replaced parts I just put new brake pads and tires on car has 36000
Old Mar 12, 2018 | 02:31 PM
Brewtech's Avatar
I had mine programmed to not come on. Not a fan of DRLs. They chew through bulbs and make harnesses brittle here in Socal. So there’s a chance the PO didn’t feel like having them on too.
Old Mar 12, 2018 | 03:12 PM
davchr's Avatar
The 2012 XKs have LED DRLs.
I know California is pretty wacky (I lived there for 30 years), but running electricity through a wire in SoCal will not make the wire brittle.
Old Mar 14, 2018 | 04:49 PM
SeanU's Avatar
This is configurable in software along with mirror auto fold on my 2011. Dealer should be able to turn it on.
Old Mar 15, 2018 | 07:38 AM
IanXF's Avatar
Good morning as of today brought the car into Dealer in Ft Lauderdale they told me car needs DRLs to be turned on using SDD so no problems I had them check the car out for other small problems like I smelled anti freeze but wasn't loosing any turned out the water pump had a leak other issue was in alarm so the are replacing the sounder and i noticed a clunk when putting it into park turns out there's a bulletin on that but the good news is all covered under CPO warranty other than diagnostic charge and they are using that to turn on the DRLs they gave me a loaner asked for an F Type but no Jag just a Hyundai so all is good
Thanks for all the replies
Old Mar 15, 2018 | 11:29 AM
Cee Jay's Avatar
Holy *****, that was one loooooooonnnnnnnnnnnnnnnnnnnggggggggggggggggggg sentence.
Old Mar 15, 2018 | 01:08 PM
IanXF's Avatar
I hate punctuation 😜😜😜
Old Mar 16, 2018 | 09:52 AM
IanXF's Avatar
Dealer just called said my 2012 doesn’t have the capability to turn DRLs on even though they are on with the headlights and no passive alarm setting anyone ever hear of that
