ABS Fault, E-Diff not available, Adaptive Dynamics fault
Old Mar 12, 2022 | 08:43 PM
pennstater's Avatar
Default ABS Fault, E-Diff not available, Adaptive Dynamics fault
Was wondering if anyone ever got these three error messages at the same time. Thanks guys!
Old Mar 12, 2022 | 09:03 PM
jahummer's Avatar
Yes many times. Do a forum search. Likely you've battery or related issues to be addressed.
Old Mar 12, 2022 | 09:21 PM
Cee Jay's Avatar
What Hummer said. Battery is low!
Old Mar 13, 2022 | 08:16 PM
pennstater's Avatar
Thank u
Old Mar 15, 2022 | 08:09 AM
khsjsilver's Avatar
Not exactly the same, but I once had 3 errors showed up on the dash:
1) ABS FAULT
2) DCS NOT AVAILABLE
3) CRUISE NOT AVAILABLE
It was not the battery, not the ABS, not the alternator and not a bad ground. It was a faulty speed sensor in my right rear wheel that was causing all the errors.
Hope this helps.
Ken
Old Mar 20, 2022 | 08:45 PM
pennstater's Avatar
Hooked up the CTEC charger and took a while to fully charge - battery seems ok, but still getting the same errors and Low Brake Fluid indicator just came on - brake fluid level visibly looks ok. Appreciate any suggestions. Thanks guys !
Old Mar 21, 2022 | 09:31 AM
guy's Avatar
guy
. Here we go again.
Define ‘seems ok’.
Old Mar 21, 2022 | 11:26 AM
Cee Jay's Avatar
The symptoms for a low voltage battery are:
ABS Fault,
jag4bob
Oct 4, 2021 04:13 AM
Philipintexas
Aug 23, 2021 10:17 AM
05XK8cfe
Jun 11, 2017 08:39 AM
wymjym
Apr 9, 2017 10:56 AM
kheestand
Oct 1, 2010 11:27 AM
