ABS module reprogramming for XK 2009
I own a Jaguar XK convertible and just replaced the ABS module with a used one.
When trying to reprogram the module it tells me that VIN routine failed as it’s different from the original VIN configuration
is there a way around this?
Am no expert on such things but the replacement ABS will be paired to the previous car, only a dealer can reflash the unit to work as don't think this is possible yourself, guessing your nearest dealer would be Beirut?
Others may chime in and say i'm completely wrong!
reprogramming a used ABS module did not work. Instead I was able to repair the old one and it works perfectly fine now!
A Technician replaced a couple of damaged parts....
Could be good to know what parts he replaced?
San Antonio Joe
Sep 20, 2018 07:12 PM
WinterJag
May 30, 2012 09:46 PM
David Type S 01
Aug 29, 2010 03:53 PM
