Accidentally refilled with Regular Unleaded....
Old Nov 16, 2021 | 08:57 PM
Splendid Cat's Avatar
Default Accidentally refilled with Regular Unleaded....
yesterday. I think it was 89 octane. I assume the car isn't going to blow up as a result, but was just wondering if it mattered one way or the other if I should mix in Premium after I get the tank down a bit or just wait and refill with Premium once I the tank is low.
Thanks.
2014 Jaguar XK
Black
Purchased May 2021 w/ 23,800 miles
Old Nov 16, 2021 | 09:14 PM
randyb's Avatar
No, your ECM can handle it, though your HP and MPG will be down. But do add premium when you can add 4-5 gallons. Also, it might take a couple of tankfuls of premium before your car is back to optimum performance.
Old Nov 16, 2021 | 09:29 PM
randyb,
Thanks so much for the information. Yet again, this forum proves its worth!
Old Nov 17, 2021 | 04:18 AM
Barry Leftwich's Avatar
Thanks.
2014 Jaguar XK
Black
89 gas aint gone hurt nothing.As long as you been putting 93 in,it's just gone subtract your octane level down to a 91 or however the graph is that you can use to add the octane levels up
Old Nov 17, 2021 | 06:51 AM
guy's Avatar
guy
drop in some octane booster.
Old Nov 17, 2021 | 12:22 PM
gkubrak's Avatar
Since your engine is not supercharged, you should be fine. As guy mentioned, for peace of mind, they do sell bottles of octane booster.
Old Nov 18, 2021 | 07:24 AM
mosesbotbol's Avatar
I would not lose sleep on it. You'll be just fine.
Old Nov 20, 2021 | 06:23 PM
DGL's Avatar
DGL
If you pumped diesel into it I would be worried. Gas is gas, no worries. A tank of regular will do no harm.
Old Nov 28, 2021 | 05:41 PM
Mandrake's Avatar
I'd be more concerned with whether what you're putting in is Top Tier gas, rather than the octane of said gas.
The sooner you add 93, the longer it'll take to remove the 89. Run it down to the gas light, then fill up with 93 and move on with life.
Old Dec 1, 2021 | 02:44 PM
lear60man's Avatar
Are these engines really that fickle?
Old Dec 1, 2021 | 04:42 PM
JagV8's Avatar
No.
Old Dec 1, 2021 | 09:25 PM
sov211's Avatar
Originally Posted by JagV8
No.
Correct answer, but you are too gentle; it should be in capitals: NO . The engines are not in any way temperamental, assuming proper maintenance. An occasional octane goof will not harm the engine but "Italian tune-ups" on lower octane should probably be avoided!
orangeblossom
Oct 8, 2015 12:08 PM
Black Cat 5791
Jun 26, 2015 12:37 AM
locrao_pt
May 3, 2015 02:44 PM
randyb
Nov 3, 2014 05:40 PM
pirat3120
Sep 18, 2013 04:49 PM
