Adaptive cruise control error
Old Feb 14, 2021 | 06:56 AM
Aartm's Avatar
Default Adaptive cruise control error
Most of the time's my ACC works well, however when a car jumps quite close in front of me from another lane, the ACC displays DRVER INTERVENE, which is normal. When the obstacle is gone, the cruise control cannot be switched back on reporting CRUISE NOT AVAILABLE. I need to stop and shut down the car. When restarting the car cruise is available again.
Any thoughts how to fix this? Is there a way to reset the cruise while driving?
Old Feb 14, 2021 | 11:36 AM
Stuart S's Avatar
Are there any Diagnostic Trouble Codes? Is your battery fully charged? Winter cold is tough on batteries.
See this thread from 2013. Your car may be affected by TSB JTB00086 software update.
https://www.jaguarforums.com/forum/x...issues-101864/
Good luck!
Old Feb 14, 2021 | 04:47 PM
Sean W's Avatar
DRIVER INTERVENE is considered a malfunction of ACC by design. CRUISE NOT AVAILABLE is then displayed. By design, ACC will not be available until the car is restarted. Try adjusting your gap.
Old Feb 14, 2021 | 06:09 PM
Cee Jay's Avatar
I get DRIVER INTERVENE all the time when using ACC when I hit the brakes or override the programmed deceleration, then I hit the RESUME button and it all works wonderfully. I can't see how it would be a malfunction when it occurs every time the driver intervenes, be it by brakes or accelerator pedal.
Old Feb 14, 2021 | 06:57 PM
Sean W's Avatar
From the manual:
  1. An audible alarm will sound, accompanied by the message DRIVER INTERVENE, if the ACC detects:
    • A failure has occurred while the system is active.
    • That using maximum ACC braking only is not sufficient.
ACC malfunction
If a malfunction occurs during operation of the system in cruise or follow modes, the ACC system will switch off and cannot be used until the fault is cleared. The message DRIVER INTERVENE appears briefly, and is then replaced by the message CRUISE NOT AVAILABLE. If malfunction of the ACC, or any related system, occurs at any other time, the message CRUISE NOT AVAILABLE will be displayed. It will not be possible to activate the ACC system in any mode.
Old Feb 14, 2021 | 08:19 PM
Cee Jay's Avatar
So Sean, IF there is a malfunction the INTERVENE will be displayed.
If the driver intervenes, INTERVENE will be displayed.
That's dumb. You'd think the engineers would have come up with something better than that.
Old Feb 15, 2021 | 03:07 AM
u102768's Avatar
If the driver brakes when the system is working normally doesn't it say Cruise Cancelled? If you press the accelerator while the system is set it says Cruise Override.
I am with you though, I spend 90% of my time using Adaptive Cruise and Driver Intervene is pretty common if you use it around town. The car has calculated that its pre-programmed maximum rate of braking will be insufficient to avoid a collision so it is asking the driver to take control. What isn't normal is it then becoming unavailable so, as Stuart mentioned, are their any fault codes being logged?
Old Feb 15, 2021 | 08:12 AM
Sean W's Avatar
I agree
Old Feb 15, 2021 | 11:46 AM
007XKR's Avatar
I need the weather to clear up so I can get mine out to verify. I thought it said 'driver override' when you hit the gas with ACC on.
Old Feb 15, 2021 | 12:22 PM
Cee Jay's Avatar
I Think it says "Cancelled" with a brake application. Driver Override or Intervene or whatever it is with the Throttle.
Old Feb 15, 2021 | 12:23 PM
Cee Jay's Avatar
Doesn't it suck to not remember something so easy and trivial when you take it for granted all the time?
That or old age, and I'd prefer it to not be that reason.
Old Feb 15, 2021 | 01:04 PM
Stuart S's Avatar
I prefer old age over the alternative.
Old Feb 15, 2021 | 05:03 PM
u102768's Avatar
I cheated and checked the 2010 owners manual before my previous post and the messages it listed were Cruise Engaged, Cruise Override, Cruise Cancelled and Cruise Not Available.
Old Feb 15, 2021 | 09:01 PM
Stuart S's Avatar
Engaged ... override ... cancelled ... not available.
I don't need a Jaguar with Adaptive Cruise to get those messages - I've been married 50 years!
Lyndon Stinson
Jan 23, 2021 07:54 AM
William Bain
Feb 26, 2020 01:42 PM
Lalub
Jul 12, 2012 11:00 AM
Davexjrv8
Nov 29, 2011 09:38 AM
