AFS Module Interchangeability
Old Jul 25, 2023 | 07:19 PM
rkellogg19's Avatar
Default AFS Module Interchangeability
Hi does any one know if the AFS module is interchangeable between years? I have a 2008 XKR and need to replace it but can't find one from the same year. Old posts I've read have asked this question but I wasn't able to find an answer. Appreciate the help.
Rob
Old Jul 25, 2023 | 08:34 PM
jahummer's Avatar
Yes they are, left for left, right for right though, can't swap sides.
Old Jul 25, 2023 | 08:46 PM
rkellogg19's Avatar
There is only one AFS module in the car so can you clarify what you mean? This is different from the AFS power modules that attach to the back of each headlight. Thanks.
Old Jul 25, 2023 | 11:49 PM
jahummer's Avatar
2007 2008 2009 will be the same, the 2010 facelift made some changes to the canbus which affect some modules but not all modules. I assume you mean the AFS ECU then, this's the part number you need
C2P23696
One place says for 2007 through 2009 another says for 2007 through 2015
Old Jul 26, 2023 | 12:23 AM
tmich's Avatar
2012+ has a different module (but you will notice that a plug has a different shape). But beforehand- should be the same. But not sure if you can have a used one (with a stored VIN number).
Old Jul 26, 2023 | 06:53 PM
rkellogg19's Avatar
Thanks for the help!
schuess100
Oct 19, 2022 04:37 AM
Tetedampoule
May 18, 2022 04:29 AM
jehart49
Oct 27, 2021 08:48 AM
Roc3207
Sep 11, 2017 05:17 PM
arthurdaley
Jan 3, 2013 11:04 AM
