Air con issues
Yep, regas. Make a note of where the connections are (on the //R one is under the air intake) so the tech doesn't suffer. Takes about 30 minutes for the machine to do it's thing, then blessed relief.
How does one add refrigerant if the can pressure is not 100lbs of pressure?
I searched all over the place to get an actual PSI figure of a can of freon, damned if I can find any info anywhere. However, 100 PSI in a pressurized can isn't unheard of anyway. Them little buggers are really packed with stuff.
Tink
Sep 1, 2016 01:04 AM
lofc2909
Sep 23, 2012 08:25 AM
ohsigmachi
Mar 16, 2010 01:03 PM
