Air Con recommendations
Old Jul 19, 2021 | 12:38 PM
Ruts XK's Avatar
Default Air Con recommendations
Hi all, My air conditioning is not cool! I took it in to In 'n' Out in Stockton and they re-gassed it. It was really good, ice cold, for a day or two but did not last long.
I'm guessing that, as it got so cool after re-gassing, that all is OK except for the gas leaking. Took it back but they said they only do a simple leak test, which seemed OK, but I need to take it somewhere with higher spec testing gear. They did offer to re-gas it after the leak was fixed. My question is, does anyone have any recommendations where I should take my hot cat to get it sorted? I saw Jagtech recommended on a different page and wondered if this is the place to go. Any suggestions welcome. Thanks.
Forgot to mention. I connected up to an iCarsoft OBD tool and am getting a code B1B78. I think this is low system pressure. The system pressure is reading 37.5 kPa which i think is about 5.5 psi.
Old Jul 19, 2021 | 01:19 PM
Sager Alanizi's Avatar
It seems from your experience that it most certainly is a gas leak since your AC ran cold after you recharged it, very simple fix for any AC specialist.
Old Jul 19, 2021 | 02:34 PM
jons's Avatar
around here we add a dye to the refrigerant, then after running the system for a little while, hunt around the engine bay with a UV light. dunno what they would mean by "higher spec" testing equipment.
Old Jul 19, 2021 | 02:45 PM
Stuart S's Avatar
Originally Posted by jons
... dunno what they would mean by "higher spec" testing equipment.
... a properly trained and equipped AC technician.
Old Jul 19, 2021 | 03:33 PM
Ruts XK's Avatar
Ha ha yeah I see what you mean. Some might regard that as high tech.
Old Jul 19, 2021 | 05:29 PM
Stuart S's Avatar
High tech is after having too many beers!
Old Sep 20, 2021 | 01:19 PM
Ruts XK's Avatar
So took car to Jagtech, they, as previous comment, filled with dye and found with UV light. Condenser leaking. New one fitted (£750), now ultra cool. Thanks for responses.
Old Sep 20, 2021 | 11:44 PM
pk4144's Avatar
Amazing, isn't it, the difference a new condenser makes?
Old Sep 21, 2021 | 12:24 AM
peterv8's Avatar
Only if the old is leaking!
Old Sep 21, 2021 | 03:47 AM
Mark,
I must have missed this thread when you first posted but would have recommended Jagtech Ltd in Stockton-on-Tees. Best independent in your area.
Old Sep 21, 2021 | 11:18 AM
MarkyUK's Avatar
GGG, that's who he used....keep up man!
Old Sep 21, 2021 | 12:27 PM
Ruts XK's Avatar
Thanks Graham, that’s good to know. They were good.
sswarden
May 23, 2023 08:56 AM
PDMiller
Jun 8, 2019 09:11 AM
worrasf
Jun 15, 2015 03:02 AM
bob5tafford
May 18, 2011 03:47 AM
x300newb
May 13, 2010 12:59 PM
