Airbag light
Old Oct 3, 2024 | 06:28 PM
Pipes's Avatar
Default Airbag light
Took my passenger seat out to remove the carpet, disconnected the seat electrical connectors without disconnecting the battery.
When I reinstalled the seat and started the car the airbag light went off briefly and came back on.
Tried disconnecting the battery and touching the leads, also checked the seat connections but all were ok.Fuse 17 ok.
Is this something for my Jag Indy to fix or is there something else to try?
Old Oct 3, 2024 | 07:28 PM
Sean W's Avatar
what happens if someone sits in the seat and buckles up?
Old Oct 3, 2024 | 08:56 PM
Pipes's Avatar
Light still on.
Old Oct 4, 2024 | 04:21 AM
guy's Avatar
guy
What code is being thrown?
Old Oct 4, 2024 | 04:45 AM
Pipes's Avatar
I’ve only got a basic reader so no code. I understand I’ll have to take it to my Indy but thought I’d ask here 1st.
Old Oct 4, 2024 | 07:15 AM
wymjym's Avatar
I pulled my pax seat one time, had to reset it and AB warning with my NT-30.
wj
Old Oct 4, 2024 | 08:03 AM
Sean W's Avatar
Save a few bucks from your indy and buy an Autel AP200. About $60 or so on Amazon. Will read all Jaguar codes including body, chassis, engine electrical etc. You can record live date while driving and push it to your laptop. You can do some minor adjustments too, like seats but no real programming. Works with a OBDII wifi dongle and the app is on your phone. I have SDD but I also have the Autel for problems like you're experiencing. Worth a shot imo
Old Oct 4, 2024 | 11:52 AM
McJag222's Avatar
Maybe a battery disconnect/hard reset might help.
Old Oct 6, 2024 | 03:38 AM
Pipes's Avatar
Thanks Sean,
I will do that.
Old Oct 22, 2024 | 02:08 AM
Pipes's Avatar
Update:
I reset it with an Autel ap200, it must’ve lit up because I unplugged the seat connections without disconnecting the battery first.
JoonasJaguar
Jul 20, 2024 06:28 AM
TreVoRTasmin
May 12, 2020 07:04 PM
sawduster
Oct 10, 2014 08:30 AM
chazaroo
Mar 21, 2012 04:41 PM
monz87
Feb 14, 2011 05:38 PM
