Alternator replacement
Old May 21, 2018 | 03:19 PM
Busyb187's Avatar
Default Alternator replacement
Hello everyone. Ok so I have a bad alternator on my 2007 XKR. They are charging me an arm and a leg to replace it so Ive decided to tackle the task myself. Ive looked around but seems like only horror stories on replacing these alternators but really no instructions or ideas on how to do it. Can anyone help on the procedure of renoving the alternator,? Again I have a 2007 Jaguar XKR. Thanks in advance to all you guys.
Old May 21, 2018 | 03:25 PM
Ranchero50's Avatar
Download the X150 service manual from the sticky's at the top of this page, read the section and see if you think you can perform the work.
Old May 23, 2018 | 12:20 AM
Brewtech's Avatar
I did it. The hardest part for me, was undoing the cover thats underneath. Raise the car on ramps, disconnect the neg on the battery and remove the fans. Then undo the serpenting belt, by releasing the tension on tensioner pulley. I used a rented tool at the time. Its just a skinny breaker bar. Now unbolt the alternator One bolt on top and the long one on the bottom. Gotta remove the airscoop for the Alternator, and the wire harness. Disconnect the power cable and it should drop down. It goes back together a lot faster.
Old May 23, 2018 | 12:24 AM
Busyb187's Avatar
that sounds pretty straight forward. I heard horror stories about the removal process. But I will be doing it this weekend so I will keep my fingers crossed.
Old May 23, 2018 | 09:57 AM
myexcursion's Avatar
Good luck and have someone with a can take pics along the way ... would make for super sticky !
Old Aug 25, 2019 | 04:47 PM
DC5Star's Avatar
Default Any update on alternator replacement on 07 XKR?
I’m having the dreaded “battery not charging” warning and not looking forward to changing the alternator
Any updates I could be encouraged by?
Old Aug 25, 2019 | 07:41 PM
sov211's Avatar
You are aware that this warning can simply mean that the battery is not accepting a charge because it is faulty? In other words it may be (probably is) the battery which is the problem.
Old Aug 26, 2019 | 01:45 AM
JagV8's Avatar
Maybe read the actual voltage at the battery terminals when the warning is showing.
If low, check elsewhere (nearer the alt) in case there's a drop.
At least you'll see if it's plausibly the alt or not.
Old Aug 26, 2019 | 01:47 AM
Sovejag13190's Avatar
Hi, why change alternator ? Its' possible regulator problem and you can change it.
Old Oct 27, 2020 | 09:23 PM
gjjaguar's Avatar
Did you not have to remove the motor mount to have enough room to drop the alt?
Old Oct 27, 2020 | 10:19 PM
Stuart S's Avatar
Wes,
The thread starter, Busyb187, hasn't made another post since 7/18/2018. I doubt that he will reply.
Stuart
From his Public Profile:
franksm
Aug 29, 2020 05:31 PM
Kamak86
Feb 28, 2017 06:19 AM
shoeboy
XJ40 ( XJ81 )
Apr 27, 2011 10:05 AM
skiplap
Feb 10, 2011 10:14 AM
mtxsho
Sep 29, 2009 05:12 AM
