Amber warning light…
Old Mar 13, 2023 | 04:04 PM
Dops's Avatar
Default Amber warning light…
Hi, I had a new main battery fitted to my XK two weeks ago at the main dealer. Now, I’ve got an amber engine warning light.
so I checked the new battery and found the Neg terminal so loose I could take it off!
would this cause the warning ?
Booked it in for a diag check, at £240 per hour!!
any advice please?
Old Mar 13, 2023 | 04:56 PM
McJag222's Avatar
Yes it's possible - get a OBDII engine diagnostic tool - something like this:
Amazon Amazon
Old Mar 13, 2023 | 05:03 PM
Dops's Avatar
Default Thank you
Ok will do
thanks
Old Mar 13, 2023 | 05:13 PM
SDCR_XK's Avatar
I will add that, if there was no amber warning light before the battery install, that is most likely what caused it.
Can you just tighten the negative cable? Might be easier than a trip to the dealer.
Old Mar 13, 2023 | 05:40 PM
Cee Jay's Avatar
ALSO, as with EVERY new battery, it needs to be fully charged! "New" batteries are never (never) fully charged upon purchase.
Old Mar 14, 2023 | 02:08 AM
Dops's Avatar
Default Thanks
Hi fully tightened the bolt, neg post is under size. That’s what I guess £300 gets you at the dealership 😫
no loss of power ext.
Old Mar 14, 2023 | 07:40 AM
texas jag's Avatar
Many auto arts dealers can and will read codes for you. It’s worth a trip to get an idea of what you are up against
Old Mar 14, 2023 | 08:51 AM
McJag222's Avatar
You could try getting a battery post shim at a local auto parts shop like these:
Amazon Amazon
Old Mar 14, 2023 | 01:05 PM
Dops's Avatar
Default Sorted thanks all
All, thanks for your replies it was all down to the poorly fitted Neg connection.
dealer sorted it and reset the light, which was letting me the MAF sensor was faulty!
always check the battery first!
Robert S
Mar 5, 2022 11:41 AM
Gary4.0
Dec 27, 2019 11:46 AM
John Sentineal
Canada
Aug 17, 2018 03:51 PM
nemesis1109
May 13, 2008 05:08 AM
