Another AirBag light question B005-11
Old Jul 30, 2022 | 08:29 PM
MudDog's Avatar
Default Another AirBag light question B005-11
2007 XK Yes Ive read a dozen posts.
Light comes on at key on, goes off then back on permanently.
Code Reader B005-11 Permanent.
Reset Restraint Module and light goes out then comes back on.
Ive got all the help files downloaded. We just finished "fixing" my EPBM issue. But this is seperate and has been on since I got the car.
Where to Start, yes horn works as does all the wheel buttons.
Old Jul 31, 2022 | 12:14 AM
jahummer's Avatar
I’m quite certain even if there’s no issue with the SRS, you’ll need SDD to reset the restraints system, at least based on personal experience.
Old Jul 31, 2022 | 03:26 AM
George Abitbol's Avatar
That's the same behaviour I'm experiencing. But of course that doesn't necessarily mean it's the same cause.
Old Jul 31, 2022 | 05:47 AM
I'd suspect the the Seat Belt Buckle isn't detecting insertion of the belt tongue.
Either the Hall Effect Sensor in the buckle is defective or the short buckle harness/connector is damaged.
Old Jul 31, 2022 | 10:05 AM
Cee Jay's Avatar
Someone said to completely pull out both seatbelts until they stop, and that may work. My memory sucks cuz I'm old, so don't remember who said it.
Old Jul 31, 2022 | 05:10 PM
MudDog's Avatar
Thanks Graham,
This must have been an in depth Code cause my scanner did not pick up this information.
Im reviewing the circuit. My seatbelt warning light on the dash does go out when I buckle up. So Im looking for other paths.
MY apology , didnt write the code down correctly.
Its B00D5-11 Restraint System Passenger Disable Indicator permanent
Scanner says "Driver Safety Belt Sensor - safety belt sensor fault "YES", safety belt sensor state - Unbuckled
Im sitting in the car , engine on, I buckled up and red seat belt light went off on dash.
Im looking at the electrical diagram, Fig 18.1 Theres ONE circuit for driver buckle. DTIC says unbuckled yet seat belt warning light goes out when I buckle up , what the heck ?
t
Old Aug 7, 2022 | 04:24 PM
MudDog's Avatar
Interesting , Air bag light is on, Im messing with the IAM front panel, unplug the 5 pin connector from the control panel , and the airbag light goes off, LOL
I dunno , just an interesting occurance. Plug the connector back in and Yep Airbag light comes back on OMG LOL
Old Aug 7, 2022 | 10:01 PM
Cee Jay's Avatar
MudDog, for a favor for me, and many other members, could you please not so much say LOL, OMG, ROFL, and such things so much? That would make me happy. Is that something you could do? Continue if you want, of course, just a mild ask.
Thank you, sir.
Old Aug 7, 2022 | 10:25 PM
jahummer's Avatar
How about emojis instead 🤣🤦🏻‍♂️😂
Old Aug 11, 2022 | 10:49 PM
MudDog's Avatar
Live Data scan shows drivers air bag deployed. But evidently its been replaced , and the steering wheel is at 1 oclock when going straight. and the light is still on.
This car is fun, pull front left wheel to change air filter,
Old Aug 12, 2022 | 04:34 AM
jahummer's Avatar
You might need a toe adjustment for the steering wheel and I reckon you still need to run an SRS reset.
Old Aug 12, 2022 | 06:18 AM
So, basically, what are the different error codes linked with this airbag warning light?
My bro in law has something to read them. It's just so I can know where my problem is actually coming from...
Thanks a lot in advance!
TommyBoah
19
Apr 26, 2022 06:21 AM
dav3uk
Jul 20, 2018 07:36 AM
Hailers
Aug 14, 2012 10:43 PM
