Anyone had this noise in their X150?
Old May 13, 2022 | 04:42 PM
Poor Richard's Avatar
Default Anyone had this noise in their X150?
Hi all.
I have a 2006 XK X150 coupe. I have a strange noise inside the car when driving that is intermittent and mildly irritating. It sounds like a Geiger counter! It doesn’t appear to be the rattle of something loose. On a long drive it won’t start until I’ve been driving for a while, and then just as randomly it will stop.
sometmes it’s quietly subtle and far away, and sometimes it’s more noticeable and louder. I’ve tried eliminating possible culprits by removing the spare wheel, cover and tools, it’s not the leather seats or upholstery.
anyone had something like this?
Old May 13, 2022 | 05:00 PM
CurtJ's Avatar
Have you checked the tires for an embedded nail or screw?
Old May 13, 2022 | 05:48 PM
Cee Jay's Avatar
OR, check that interior exasperator or whatever that fan thing is on the dash that looks out of place. The insides can get dusty dirty and interfere with airflow. Take off the cover and GENTLY clean out the insides.
Old May 13, 2022 | 07:04 PM
B SMITH's Avatar
I had a annoying noise that would randomly start and stop at various speeds.
It took me awhile to find it. I had the car on my lift for a oil change and spotted the problem. The dust shield on the differential was cracked and loose. It would start spinning with the driveshaft and sent a humming noise through the car.
Dust shield
Old May 13, 2022 | 07:24 PM
Cee Jay's Avatar
Originally Posted by B SMITH
That's one nice looking adjustable wrench you got there
Old May 13, 2022 | 08:11 PM
B SMITH's Avatar
Thank you 😊
Its aluminum for AN fittings.
Old May 13, 2022 | 10:21 PM
Cee Jay's Avatar
All my A/N fittings look like crap. Mostly because they used to be on aircraft, and also because of open-end wrenches. My newer ones are still nice though.
Old May 13, 2022 | 10:37 PM
gctippett's Avatar
Well if it doesn't start (car) it might be the battery terminals are need of a cleaning (is the battery old ?)
Old May 14, 2022 | 12:42 AM
peterv8's Avatar
Reread first post!
Old Dec 29, 2023 | 05:29 PM
howdoyousayjaguar's Avatar
Dust shield
Does this require a lift or any disassembly to remove the dust cap? I'm having the same issue.
Thanks!
Old Dec 29, 2023 | 05:50 PM
B SMITH's Avatar
Thanks!
You will need to jack up the car high enough to slide under and pull it off. Nothing needs to be removed to gain access.
Old Dec 29, 2023 | 07:42 PM
kj07xk's Avatar
Understandable, but surely you need to disconnect the drive shaft to install a new one?
Old Dec 29, 2023 | 09:21 PM
B SMITH's Avatar
I live in Las Vegas. I put about 1000 miles a year on it running errands. I have other vehicles and have never driven it in the rain. I haven’t worried about replacing it.
If a new one doesn’t have a split in it you need to drop the driveshaft.
Old Dec 30, 2023 | 01:57 AM
Woo5ie's Avatar
If the noise sounds like an intermittent Geiger counter then the culprit could be the Sounder.
it sits under the bonnet below the airbag that pops the bonnet in an accident.
I believe the sounder is permanently in CCT and when faulty can run the battery down
A little difficult to get to but can be done.
The sounder is the same as a Ford one..
It’s the thing that beeps when locking the car.
In the UK we may not have the beep as it is possibly programmed out as mine is.
I changed mine when I got the Geiger counter noise and replaced with new Ford one off Ebay for a fraction of the cost from Jaguar
The change procedure has been written up on here. Search on sounder
frank barone
Aug 9, 2021 07:25 PM
peterv8
Oct 3, 2017 08:41 PM
JimC64
31
May 30, 2016 03:04 PM
Pagline
Mar 5, 2015 01:19 PM
