Aston Martin DB9 brakes
Old Mar 25, 2018 | 10:25 AM
onbevreesd's Avatar
Default Aston Martin DB9 brakes
Hi everyone
Did anyone has tried to fit DB9 brake callipers to XK?
Brake discs size is same as XKR.
Any thoughts?
Old Mar 25, 2018 | 10:58 AM
Cee Jay's Avatar
Just me asking here...... would there be a benefit to putting DB9 calipers/pads on an XK?
Also, to which years are you referring?
Old Mar 25, 2018 | 11:07 AM
onbevreesd's Avatar
I wasn't thinking about anything else than looks. DB9 has lovely Brembo monoblock callipers, not a cast floating ones like Jags have.
Plus in the UK you can buy DB9 brake callipers for less than XKR ones.
Old Mar 25, 2018 | 02:40 PM
Ranchero50's Avatar
Buy one and find out. If it works, buy the other. If not return it.
Old Mar 25, 2018 | 02:43 PM
Cee Jay's Avatar
I've changed brake systems on several cars, and never used a kit once. Cutting, welding and otherwise fabricated half-inch steel plate and such, and it always worked out great.
Old Mar 25, 2018 | 04:22 PM
mosesbotbol's Avatar
DB9 has carbon ceramic brakes, so you'll have brakes that can go 80K miles, keep the wheels much cleaner and easier to wash.
That being said, I would see if the Jaguar's CCB brakes would work.
Old Mar 25, 2018 | 07:10 PM
jahummer's Avatar
Originally Posted by onbevreesd
Hi everyone
Any thoughts?
You'd be better off with the Alcon package Jaguar offered for 2008 & 2009. The Jaguar carbon brakes will fit as well but unless already in the bundle offered, require adapter brackets that are quite costly. There is one off an F-Type listed on eBay in the UK for 7K sterling but the X150 brackets are not included.
Old Mar 26, 2018 | 11:28 AM
onbevreesd's Avatar
Alcon if fine but is about seven times more expensive than Aston brakes
Old Mar 26, 2018 | 11:44 AM
Cee Jay's Avatar
I just did a search for calipers for DB9. The cheapest I found were $268 each, used.
XKR cost $150 each used.
ALCON is $800 for both front, again used.
I guess large bodies of salt water make a difference.
Old Mar 26, 2018 | 08:55 PM
Cambo's Avatar
If you want a cheap/easy bolt-on Brembo solution then the front brakes from a 2003-2005 XJR or S-Type R will fit. 4-piston, slightly bigger 365mm rotors
You need to swap the vertical link / knuckle over from the XJR/STR, but aside from that it's more or less a straight swap.
Old Mar 26, 2018 | 08:58 PM
Cee Jay's Avatar
^^^^^^ Won't help me, I have the 380mm brakes already.
Old Mar 26, 2018 | 09:30 PM
Cambo's Avatar
Originally Posted by Cee Jay
^^^^^^ Won't help me, I have the 385mm brakes already.
Well I wasn't talking to you specifically The OP has an XK with 355mm fronts.
And actually your fronts are 380mm, if we are going to be precise.
Old Mar 27, 2018 | 08:51 AM
8bit's Avatar
Some Range Rovers have what look like fairly substantial Brembo calipers on large discs, anyone ever looked into swapping those onto an X150?
Old Mar 27, 2018 | 09:14 AM
Current Jaguar line up across the board has lackluster looking brakes except for the carbon ceramic ones. The Alcon's look cool, but is on the smallest percent of cars. Alfa and Maserati put nice looking brakes on their cars at all price points; Jaguar needs to do the same.
Crovax
Nov 3, 2014 08:20 PM
powerhouse
Aug 14, 2014 05:56 AM
jagxkrtoofast
Nov 23, 2010 07:36 AM
Brian2000XKR
Aug 10, 2010 04:39 PM
