Auto smells burnt at high speed
Old Aug 6, 2018 | 09:29 AM
Jagstefano's Avatar
Arrow Auto smells burnt at high speed
I have been the lucky owner of my beautiful Jaguar xk for over 2 years
He is from 2006 and has walked about 160,000 km.
Now I have some (problems) when I give a little bit of gas or hard. above 180 km per hour, that the car a little inside to smell the engine. I can hardly describe what it smells after. Burned oil for example. What could it be, because it seems to get worse.
Could someone help me about this.
Old Aug 6, 2018 | 09:35 AM
NBCat's Avatar
Check for oil leaks or seepage around the cam covers as it can get onto the exhaust manifold.
Old Aug 6, 2018 | 10:22 AM
pwpacp's Avatar
Also, verny nice cat!
Old Aug 6, 2018 | 11:20 AM
kj07xk's Avatar
Had a similar issue, could smell it, then last winter it actually leaked oil onto the floor.
Turned out that one of the bolts holding a valve cover was loose (almost falling out).
Some previous service to the car had failed to tighten all the bolts (this one was out of sight and hard to get to).
Old Aug 6, 2018 | 11:55 AM
Jagstefano's Avatar
Thanks for your comment. Do you know where the cam covers are?
Old Aug 6, 2018 | 11:56 AM
Jagstefano's Avatar
Originally Posted by kj07xk
+2
Hope it is. I'll look at that. how can it eventually leak in you? is it going to run along the engine block?
Old Aug 6, 2018 | 11:58 AM
NBCat's Avatar
Perhaps you should take the car to a Jaguar agency or specialist shop for diagnosis.
Old Aug 6, 2018 | 02:18 PM
kj07xk's Avatar
Here's a link to the thread on my issue.
https://www.jaguarforums.com/forum/x...l-leak-199975/
I think I had the big leak, which made the existing small leak evident, because I started the car in the winter without allowing the car to warm up.
It ran long enough to pump oil up to the top of the engine, then I shut it off. Since the engine didn't heat up enough for things to expand and seal the gap, the oil leaked out where the valve cover wasn't tightened down.
Old Aug 6, 2018 | 02:30 PM
10XKR's Avatar
Please double check the coolant level.
Dave
Old Aug 7, 2018 | 03:38 AM
peterv8's Avatar
Nice pic!:-)
Old Aug 26, 2018 | 10:44 AM
Jagstefano's Avatar
I am going to bring the car to the mechanic. I just found out that the battery is empty all the time. everytime I am taking the car. the battery is dead. I think it has a connection with the smell of the car. don't you think?
Old Aug 26, 2018 | 11:32 AM
Ranchero50's Avatar
No, separate issues and separate smells.
Old Aug 27, 2018 | 05:41 AM
MarkyUK's Avatar
I think it helps to have a set of ramps for such things, then you can usually identify oil/transmission/collant leaks quickly.
Can I ask at 160k kms how many times your transmission has been serviced? I think Jag states 'sealed for life' but ZF says every 80k kms, so your car should have had two.
Old Aug 27, 2018 | 07:44 AM
Ranchero50's Avatar
Exclamation
When one doesn't know where the cam covers are you do not recommend driving on ramps...
Baby steps my friend.
Old Aug 28, 2018 | 07:29 AM
Jagstefano's Avatar
Hi there
the card didn;t had any service for the box. the gear is also doing weird
Old Aug 28, 2018 | 10:44 AM
MarkyUK's Avatar
Driving up on ramps is IM(not so H)O the same as driving up a steep slope?
You don't NEED to know where anything is to check that anything is/isn't leaking
My friend
Strokeman
Mar 27, 2016 08:27 PM
Dmac64
Nov 9, 2011 06:20 AM
1stingfan
Jul 30, 2010 04:24 PM
NorCalDiesel
Nov 23, 2009 10:15 PM
GonzoBassPlayer
Jun 18, 2008 07:31 PM
