Battery
Old Jan 25, 2024 | 12:37 PM
markva44's Avatar
Default Battery
Hi all
Im thinking of replacing my battery. Ive searched this forum but they seem to go off topic. I just want a good brand battery that will fit perfectly into the original battery tray. I dont want any non spec battery, just a battery to fit which is a good brand.
Any suggestions please?
And can I connect my ctec to the neg and positive to keep the memory while swapping?
thanks in advance.
Old Jan 25, 2024 | 01:25 PM
Cee Jay's Avatar
Pretty much ALL batteries (US and UK) are made by the same company. Just get one with good CCA and the right group size and Carry On. Group 49 or H8 for you. AGM is fine, but not a significant improvement for the price since neither will last much longer than five years regardless.
Sometimes CTEKs won't provide any voltage unless it senses the presence of a battery. I'd not rely on that. Hooking a spare battery to the underneath jump points with cables is the safest bet, but then be CAREFUL with the detached cables as they will have power.
Old Jan 25, 2024 | 02:00 PM
David993S's Avatar
Probably not news, but Interstate (along with other brands) makes a battery that's the correct fitment for the XK. I just recently had to replace the battery in my new-to-me '09 XK - don't have the model number, but my shop looked it up. It was $299 with tax. I use my Nocco battery pack to keep 12v flowing if changing a battery.
Old Jan 25, 2024 | 04:01 PM
SDCR_XK's Avatar
Interesting. Recently, buying a battery for my wife’s car, I was told that, “Interstate doesn’t make batteries anymore”. They then sold me a Diehard, which fit fine and had high CCA.
Old Jan 25, 2024 | 04:19 PM
David993S's Avatar
Sounds like a shop that wanted to sell what they stock. Nothing wrong with Diehard. Interstate still "makes" batteries.
Old Jan 25, 2024 | 04:57 PM
Tiepolo's Avatar
Hi,
I just changed mine and from my research I found that the Varta H3 are one of the best here and the bigest capacity you'll find in this size ( i found a 110aH before but once received I realised it was slightly too big :-( )
https://innpo.fr/de-80ah-a-105ah/bat...h-a-105ah.html
Originally Posted by markva44
Hi all
thanks in advance.
Old Jan 25, 2024 | 05:05 PM
Stuart S's Avatar
Note the OP is in the UK, not the USA.
Old Jan 25, 2024 | 05:10 PM
OzXFR's Avatar
I must hesitate to differ!
The original battery (AGM) in my F-Type is still going strong at 9.4 years old and has never glitched once or ever given me a problem.
I put this down to the fact that I hook it up to a battery tender (not a CTEK but same function) via the under-hood jump points pretty much whenever the car is parked in my garage.
Another possible factor is that I disconnected the start/stop secondary battery on day one of ownership 7.5 years ago and then removed that secondary battery completely about four years after that, anecdotal evidence is mounting that having a flat/dead/dud secondary battery connected up contributes to earlier failure of the main battery.
A number of F-Type owners here also report OEM batteries lasting for many years, one or two at 10 years +, and most regularly use a tender.
Last but not least I live in a fairly warm climate so the battery never suffers from getting really cold.
Old Jan 25, 2024 | 07:06 PM
Cee Jay's Avatar
Originally Posted by OzXFR
I must hesitate to differ!................F-Type.............F-Type...................
Yeah, F-types have better electronics. We all know that.
I had an AGM in my XKR. It lasted just over five years, exactly like the previous Non-AGM lasted which cost $70 less than the AGM.
I stick to what I said.
Old Jan 25, 2024 | 08:51 PM
David993S's Avatar
I feel cheated if I don't get at least 7 years out of a battery (non-AGM). I keep all my cars on tenders and they typically last 7-8 years. The longest I've ever had a battery last was in my 993......12 years. I swear.
Old Jan 28, 2024 | 07:31 AM
markva44's Avatar
Theres so many batteries. Do you think this one will fit in the tray and be suitable please?
Type 017 Varta Black Dynamic Car Battery 12V 90Ah (Short Code: F6) (Varta DIN: 590 122 072) (tayna.co.uk)
Old Jan 28, 2024 | 09:53 AM
Cee Jay's Avatar
That thing has no sizes listed, other than the actual dimensions. It also seems pretty weak, but it is a bit lower cost. Your own guess as to if it will fit. It SHOULD have something like this listed...
Group 49 (H8, L5, 88L5)
Old Jan 28, 2024 | 11:23 AM
markva44's Avatar
I would of thought it would be a simple task picking a battery. I did some googling and this one came up on the F Type forum.
Varta 019 (H3) Silver Dynamic Car Battery 12V 100Ah - 600 402 083 (tayna.co.uk)
Jody Harms
Oct 10, 2020 11:29 AM
jammer
Mark V - X 420G
Oct 12, 2018 11:31 AM
DRV4SHOW
Aug 10, 2017 06:23 AM
Cadillac
General Tech Help
Sep 23, 2014 12:39 PM
estunum
XJ40 ( XJ81 )
Nov 16, 2007 02:18 AM
