Battery PSU for while programming etc
Old Jun 19, 2024 | 12:06 PM
justinhill's Avatar
I don't know the construction and design of these modules but if the programming is stored in EEPROMs then yes, a good deal more power during programming than normal operation.
Old Jun 19, 2024 | 01:34 PM
jahummer's Avatar
Originally Posted by XKDreams
I still don’t understand why just programming would draw that much power. Computers and their memory dont draw much more current during programming than during “normal” operation. But, if you are hooking up the diagnostic tool, and activating different loads such as windows, heaters, etc…in the process of diagnosing a problem, I can then see the large power draw.
Yes, programming often does go through multiple cycles and autonomous control of various functions of the vehicle and the read/wrote times can be very long for some, more 30 minutes and longer, fans lights and more running with the generator switched off depletes the battery quickly. This isn't unique to Jaguar either.
Old Jun 19, 2024 | 01:48 PM
McJag222's Avatar
Although eeproms require more power during programming they are very low power and would not account for the need for a 50A PSU.
Old Jun 19, 2024 | 02:18 PM
kj07xk's Avatar
Since the SDD power supply requirement for my 2007 is 25A (minimum), I bought a 30A supply.
When I first started just poking around, I figured it wasn’t going to take much juice, so I connected the supply to my battery maintainer leads, which should be able to handle 15A. Wasn’t long before the battery indicator on SDD dropped to ‘red’, so I knew it wouldn’t be sufficient to handle programming later. I got some cheap jumper cables to connect to the positive post behind the right hand panel in the trunk/boot, and a chassis ground. The thicker wire allowed enough juice to flow to keep SDD happy with the battery indicator staying green. Lots of stuff stays active in the car when SDD is running.
Old Jun 20, 2024 | 03:30 AM
justinhill's Avatar
I haven't used it in battery support mode yet but I'm happy with my new purchase so far. It has essentially the same features as a CTEK (although obviously not as compact!). The supplied cables aren't heavy-duty enough but I can replace them.
Old Jun 26, 2024 | 09:18 AM
Cee Jay's Avatar
While using SDD and my CHARGER, the amp draw is usually about 30-34 amps. That's a bit, but there also a LOT of modules and such. All running.
Old Jul 27, 2024 | 07:55 AM
justinhill's Avatar
Just thought I'd chime in to say that today, with the boot lid and doors open, the car in accessory mode and the AP200 connected and scanning for codes, my battery support unit was reading between 22A and 26A.
Lug_Nut
Oct 26, 2023 07:29 PM
Lothar52
Dec 10, 2022 03:10 PM
sam1977
Jul 8, 2020 05:38 AM
Car Crazy
Jan 27, 2019 07:59 PM
mij86
Jan 13, 2018 12:11 PM
