best way to lower a xkr?
Old Aug 15, 2014 | 10:12 PM
Austinmcdonald's Avatar
Default best way to lower a xkr?
I want to lower my xkr but not to low just to make it look good. I Also want it to ride and handle good. What's the best method? Bags,adj. Coilovers, or lowering springs?
Old Aug 15, 2014 | 11:46 PM
axr6's Avatar
You need to search the forums as this subject have been discussed a lot. The springs are the least expensive options, generally dropping the car about 1.5". The coil overs are much more expensive but, they are also a much better option since you can adjust your ride height.
Also, a problem that may pop up with lowering is that the rear wheel cambers are non-adjustable on late Jaguars which means that you could pick up too much negative camber and wear-out the tires on the inside.
Old Aug 16, 2014 | 05:20 AM
Mike V's Avatar
If you have a 2010+ XKR I have some XKR-S lowering springs for sale. They lower the 2010+ models by 10mm and have stiffer spring rates.
If you have a pre-2010 model I also have some H&R springs that will lower it 35mm.
I had started with the R-S springs but they didn't properly fit my 2008 model so I got the H&R springs. Now I'm selling the Jag so everything is going back to stock.
Old Aug 16, 2014 | 11:56 AM
sherbercars's Avatar
With the h&r springs how did you find the rear tire wear ? how many miles did you have them on ? Bernie
Old Aug 16, 2014 | 04:29 PM
Mike V's Avatar
Tire wear was fine, if anything my Michelins seem to have worn in the middle more than anywhere else which I blame to dialing in the perfect tire pressure.
I got about 2000 miles on them and they really fill out the tire well perfectly however I did park curbside a lot more often when I went to places with odd drive entrances, like a dip then an incline type driveways.
Old Aug 19, 2014 | 01:09 PM
Its a 2004 xkr and how much for the h&R's if they will fit my year?
Old Aug 19, 2014 | 10:04 PM
ralphwg's Avatar
You are in the wrong thread. There is another thread dedicated to XK8s and their supercharged brothers. Try there you will get better answers.
Old Aug 21, 2014 | 11:26 PM
OK thanks man
Old Aug 22, 2014 | 10:21 AM
jonscot's Avatar
Austin, I'm in both threads, have both cars - we have a pretty good list of discussions there on lowering - and I just saw a 1.5 lowering kit on ebay for 300 bucks.
GordoCatCar
Jan 2, 2017 01:10 PM
Dan
Sep 17, 2015 05:54 PM
Tim Goz
Sep 17, 2015 09:11 AM
SeanU
Sep 14, 2015 04:31 PM
mhamilton
Sep 12, 2015 03:21 PM
