Blower motor
Old Oct 4, 2015 | 08:35 AM
carlprs's Avatar
Default Blower motor
I have a 2008 xkr. The blower stopped working so I removed it. Fuse is good. When I start the car it blower turns for about two seconds then stops. I tried it in auto and manual. Is there a starting coil. I'm hoping it's not a computer issue. Any help greatly appreciated.
Old Oct 4, 2015 | 09:53 AM
WhiteXKR's Avatar
Might be worth checking for this: https://www.jaguarforums.com/forum/x...08-xkr-147151/ and https://www.jaguarforums.com/forum/x...firmed-148043/
Old Oct 6, 2015 | 08:14 PM
Dan's Avatar
Dan
I ended up having to replace both the blower control module and the fan. The fan bearing was making noise and would be stuck if I left the car for several days without driving it. All of this is from the fact that the AC is not draining...big pain in the butt
Old Oct 7, 2015 | 07:45 PM
carlprs's Avatar
Default Blower
I did have the drainage problem. I tried the drain tube fix in a thread on the forum but it didn't work so I got the $700 dealer repair. Hopefully this will be the last bit of trouble from what should be a recall repair.
Buckingham
Sep 16, 2015 02:15 PM
daniel06
XE ( X760 )
Sep 15, 2015 07:07 AM
Ceckman
Sep 11, 2015 04:38 PM
Oldbill1
Sep 10, 2015 10:24 AM
joesoap
Sep 10, 2015 01:09 AM
