Brake Pads?
Old Aug 21, 2014 | 08:55 AM
MrSTarhouse's Avatar
Default Brake Pads?
The warning for worn brake pads just came up in my car. I lifted it and checked, and it is the rear ones that require changing.
However, when trying to find what part number they should be, its's all a bit of a jungle.
My car is a 2009 (MY2010) XKR 5.0 Supercharged Coupe. Standard brakes, No Alcon or other specials.
Iv'e found several part numbers, but it seems uncertain whichh is the correct:
-C2D3792
-C2P17595
-C2C27271
Any of these? Or something else?
Also. Is ai always nescesay to replace the wear sensor? Or is it possible that it might be reused?
Old Aug 21, 2014 | 09:32 AM
daxter1987's Avatar
Here is a guide with the part numbers according to ALLDATA: jaghelp.com: 2010 XK Factory Brake Pads part numbers
Old Aug 21, 2014 | 09:33 AM
daxter1987's Avatar
If your brake light is on that means that the wear sensor needs to be replaced.
Old Aug 21, 2014 | 04:32 PM
bobdr1's Avatar
I know that my front brakes on the 2010xk are going to need replaced soon. Jag dealer just looked at them and said they had 4mm left on them, advised me to wait until sensor goes off then replace pads/rotors and sensors. I already have a set of ceramic front pads and rotors waiting for the time to replace the fronts. If I go ahead and have them replaced before the sensor lights up can I avoid having to buy a new sensor? Thanks
Old Aug 22, 2014 | 07:04 AM
arkmark's Avatar
Default pads
Hi,
If you need a set of pads I have a set of original Jaguar pads left over from a job. Can post from the UK £35 plus post (I can check cost of post)
thx
Old Aug 22, 2014 | 07:32 AM
daxter1987's Avatar
Well there is an art to that, you have to pull the sensor carefully so it doesn't break... is practice. I've done a couple of hundred and I still break it sometimes... But yeah, if you manage to carefully pull the sensor without damaging it then you don't need to change it.
Best of luck!
Old Aug 25, 2014 | 03:38 AM
Well now, this mystery continues. The one I should use according to above link are told to me that they are for normal XK, not XKR.
My rear discs are normal vented, but not drilled or slotted. The diameter is 380mm.
The suggestion I got now are C2P25493 which is supposed to be for XKR 5.0L Supercharged 2009 and onwards.
But these are considerably more expensive, and there doesn't seem to be any alternative brands there.
A Djungle, this is :-)
Any ideas are welcome.
Old Aug 25, 2014 | 04:32 PM
arkmark's Avatar
Default brake disc info
Hi,
Brake disc info as follows,
Jaguar XK (X150 model)
front disc 326mm / 326mm rear (mainly 4.2l non supercharged)
front disc 355mm / 326mm rear (4.2l supercharged and 5.0l non supercharged)
front disc 380mm / 376mm rear (5.0l supercharged)
All above with STD non grooved discs
Also option was on offer for 5.0l supercharged and others if requested
380mm Alcon front with 376mm ALCON rear (grooved disc)
I hope that helps and if you need any discs or pads for the above let me know.
thx
Old Aug 26, 2014 | 01:13 AM
Originally Posted by arkmark
Hi,
thx
The rear discs are around 380mm, so I guess it's the 376mm ones. And there are no grooves, so iy shouldn't be the Alcon type.
And yes, I am looking for discs. This special 376mm ones seams more expensive then all the others, by a lot. And there doesn't seem to be any alternatives. The part No: C2P25493 I got from S.N.G Barrat UK.
Below is a picture of the caliper and disc where I have removed the R-Badge
Old Aug 26, 2014 | 12:06 PM
arkmark's Avatar
Hi,
I can confirm I have the following (all original Jaguar parts)
Rear discs pr of £125
Rear pads car set £35
Wear wires pr of £30
all plus postage.
Please let me know if they are of interest on my email address mhogg@talk21.com
thx again
H20boy
Dec 24, 2024 03:23 PM
perezal
Dec 29, 2015 08:48 PM
ahunt4
Sep 19, 2015 09:49 AM
1964Daimler
Sep 9, 2015 11:28 AM
JagLove86
Sep 6, 2015 10:36 PM
