a/c refrigerant low
Old Jun 10, 2014 | 10:17 AM
kj217's Avatar
Default a/c refrigerant low
the a/c works fine in mt 07 XKR but sometimes cooling goes a bit down and starts a hissing sound,,
a/c tech said that refrigernat needs a top up but we couldn't locate the filling nipple,,
do you think refrigerant is low?
can you help me locate the filling nipple?
Old Jun 10, 2014 | 06:28 PM
RedRider48's Avatar
I hesitate to offer this, but will anyway, locate the 'larger" of two dia AC lins connected to the compressor. This will be the low pressure or suction line. On this line (larger of the two) should be a schrader valve (like a bicycle tire) fitting. Forgive me is I make this sound so juvenile, as I don't mean too. Just want to insure one is making the right choice.
Happy Motoring...
Old Jun 13, 2014 | 08:54 AM
kj217's Avatar
Happy Motoring...
thanks a lot for the info,, but do we also need to locate the high pressure port?
Old Jun 13, 2014 | 09:16 AM
This might help. https://www.jaguarforums.com/forum/x...d=2#post785940
Old Jun 13, 2014 | 09:30 AM
RedRider48's Avatar
OK, if by what you call a "pressure port", you are referring to the port for attaching the hose for filling with freon, then, this is the schrader valve term, to which, I was referring. Most all of the 134A filling containers, I've seen offer a "how to" on the process.
Keep two thoughts in mind....
1. idle the engine
2. turn your AC system on high
If you have, (you should) what's called a "pencil thermometer", insert it in a central AC outlet. Then have it....good luck!
pk4144
Sep 24, 2015 08:29 PM
swetnK
Sep 23, 2015 10:49 AM
NTL1991
XJ40 ( XJ81 )
Sep 20, 2015 06:22 PM
Vee
Sep 13, 2015 12:19 PM
Saturbo
Sep 8, 2015 07:35 PM
