Can indicator sound be disabled?
Old Apr 7, 2018 | 06:42 PM
Ter11's Avatar
Default Can indicator sound be disabled?
Hi all
If indicators are active the car makes a respective noise imitating a switch clicking. Can this sound be disabled and if yes, is this something only the dealer can set?
Reason I am asking: I am used to hear this indicator sound. But one XKR I drove recently did not give any audible feedback when the indicators were active. So I guessed that the sound had probably been disabled.
Br
ter
Old Apr 7, 2018 | 07:14 PM
ralphwg's Avatar
Are you talking about turn signals? Your question does not make that clear. In any case, to the best of my knowledge there is no way turn the turn signal "click" off. Furthermore, I don't understand why one would want to turn the "click" off.
Old Apr 7, 2018 | 07:23 PM
jagtoes's Avatar
I don't know but assume that the turn signal "clicker" in todays cars are some sort of solid state device. In older cars there was a turn signal relay which was intentionally designed so you would hear the relay make/break contact thus the clicking sound. There were different sound level relays that you could buy to either increase or decrease the noise but there was always a sound. So if there is a replaceable relay in the Jag system I would suspect you could get a more silent relay.
Old Apr 7, 2018 | 08:08 PM
Cambo's Avatar
There is a speaker on the circuit board in the instrument cluster for the indicator ticks. It's known for this speaker to fail, and no ticks anymore... happens in the XF as well. Dealer will tell you a replacement instrument cluster is needed, but anyone good with electronics is able to replace it with a steady hand and a soldering iron.
Old Apr 8, 2018 | 09:17 AM
Ter11's Avatar
Dear all
Thanks for the explanations. So it looks like something is broken on that XKR that needs to be fixed to bring back the turn signal audio feedback. Will look into is...
ter
cyber3d
May 28, 2017 05:09 PM
Jrp79
Mar 14, 2017 07:46 PM
Jens boy
Nov 20, 2015 06:10 PM
jhh
Oct 31, 2009 05:11 PM
adam12hicks
Feb 12, 2009 11:39 AM
