Car cutting out and gear selector flashing D - RESOLVED
Old Feb 23, 2020 | 07:12 PM
joedinfl's Avatar
Default Car cutting out and gear selector flashing D - RESOLVED
Hi everyone - seeking advice. I was driving my 2011 XKR earlier today and when I came to a stop sign, the engine just cut out - this has happened a few times over the last few months. I then went out later in the day, and the same thing happened. I just re-started the car again, and then whenever I came to a stop, the engine would start idling very low and the gear selector kept flashing D - I was able to put it into N and then D, and I could then accelerate again, but the car was very "jumpy" - this happened about 5 times, and the idle seems inconsistent. I have an icarsoft tool, and the following codes were displayed:
P010B Mass or current air flow B circuit - range/performance
P0500 Vehicle speed sensor A / Vehicle speed sensor circuit malfunction
B100A Fuel pump authorisation
U0415 Invalid data received from ABS control unit
U2005 Vehicle speed
U1A24 MOST ring complete. no communication
U0140 Lost communication with body control unit
Any ideas on what is wrong with the car - I was thinking it had something to do with the throttlebody or fuel/air mixture ?
Thanks in advance,
Joe
Last edited by GGG; Feb 28, 2020 at 02:17 AM. Reason: Add "RESOLVED" to thread title
Old Feb 23, 2020 | 08:05 PM
Stuart S's Avatar
I suggest that you download the 5.0L XK Workshop Manual and Electrical Guide in the sticky at the top of this Forum home page for troubleshooting advice.
Old Feb 24, 2020 | 06:23 AM
pwpacp's Avatar
+1 with Stuart S.
At the outset though, it seems to point to an ECM communication issue. If others have had the same or similar issues, perhaps they'll chime in.
Old Feb 24, 2020 | 06:40 AM
guy's Avatar
guy
Precisely right. Been there, done that with loosened connectors and modules in the past.
But I’m lazy. With so many codes I’d call a flat bed.
Old Feb 24, 2020 | 05:35 PM
George05's Avatar
Time to book it in to a good indy garage. update us please
Old Feb 25, 2020 | 01:06 AM
peterv8's Avatar
I'd write down the codes and then erase them to see if the same codes came back the next time.
Start checking connectors.
Batttery ok? Alternator ok? You can get some weird symtoms with low voltage.
Old Feb 25, 2020 | 02:49 AM
Originally Posted by peterv8
I'd write down the codes and then erase them to see if the same codes came back the next time. ......
+1
Always. Out-of-range signals happen all the time. No reason to jump to the conclusion a particular DTC is a permanent fault before checking for repeatability.
Old Feb 25, 2020 | 08:57 AM
joedinfl's Avatar
Thanks for all the advice guys. Car is now in the garage - I'll let you know what they say.
Old Feb 27, 2020 | 09:56 AM
joedinfl's Avatar
Quick update for you - and I must admit, I'm fairly embarrassed about not looking properly to see the problem (a case of not having enough time)!!! So, the reason it was behaving strangely was that one of the air intakes (that eventually go to the throttle body) had worked it way loose - so fortunately a very easy and cheap fix :-)
Old Mar 1, 2020 | 04:45 PM
Don-T's Avatar
And we appreciate the comeback on the resolution. Too many times folks just seem to disappear after asking for assistance so we never find out what happened.
BobRoy
Mar 18, 2017 10:48 AM
detonator
Sep 4, 2016 09:57 AM
Bcrary3
Apr 29, 2015 09:47 AM
devxiav
Jan 7, 2015 11:22 PM
Maninahat98
Sep 4, 2013 12:55 PM
