Clearing warning symbols
Old Mar 5, 2017 | 12:56 AM
steve_k_xk's Avatar
Default Clearing warning symbols
Discovered that it is actually possible to clear warning symbols via the interactive display unit
Once the warning symbol occurs on the dash a very very small red rectangle shall appear on the interactive display unit, from then on its as simple as pressing the red triangle and following the prompts
Attached Thumbnails Clearing warning symbols-photo718.jpg   Clearing warning symbols-photo4294966616.jpg   Clearing warning symbols-photo314.jpg
Old Mar 5, 2017 | 09:01 AM
kj07xk's Avatar
Cool! I wondered what that little bugger was for.
Old Mar 5, 2017 | 12:05 PM
Cee Jay's Avatar
Yep, that's all in the owner's manual.
Old Mar 5, 2017 | 02:26 PM
kj07xk's Avatar
Guess it didn't bug me enough to look it up.
Old Mar 5, 2017 | 03:44 PM
tberg's Avatar
I use it to get rid of the pesky, "blaring" low fuel warning about every other day.
Old Mar 5, 2017 | 07:11 PM
steve_k_xk's Avatar
Seems like I'm the only one that doesn't know it was possible to clear these symbols
Ceejay where abouts in the manuel is it would you be kind enough to post up a pic
Old Mar 5, 2017 | 07:42 PM
AllblueACR's Avatar
Me either.....
wonder if it clears the service required
Old Mar 6, 2017 | 12:51 AM
u102768's Avatar
Here you go. This from the 07 owners manual.
Old Mar 6, 2017 | 09:08 AM
tberg's Avatar
It doesn't clear the "service required" warning, but there is a complicated sequence that does, it's been posted here before.
Old Mar 6, 2017 | 12:16 PM
Cee Jay's Avatar
Ceejay where abouts in the manual is it would you be kind enough to post up a pic
There's this one;
And the Service Required Reset;
And the Service Required Reset Procedure;
'Service Required' Message appears on dashboard (2009+ models in the UK, 2010+ models
elsewhere):
-This service reminder message sometimes appears as a result of the battery disconnect. Reset
it as follows:
1. Press and hold the rear fog lamp switch (before the ignition is on).
2. Press the start button without applying the foot brake (do not start the engine)
3. Release the rear fog lamp switch (1sec)
4. Press and hold the trip computer cycle switch (within 1sec).
5. Press and hold the rear fog lamp switch. (within 1sec)
6. Continue to hold the trip computer and rear fog lamp switches.
7. The message center should display "resetting service mode" and then "service mode reset"
8. Release the trip computer and the fog lamp switches and turn the ignition off.
Old Mar 6, 2017 | 05:00 PM
sov211's Avatar
You should not ignore the low fuel warning. Are you aware that the fuel pump is cooled by the fuel around it? The major cause of fuel pump failure in modern cars is repeated running of the pump in a low fuel environment. Resist the urge to run it below 1/4 tank...replacement of a fuel pump is an expensive repair.
Old Mar 6, 2017 | 07:03 PM
shemp's Avatar
There's this one;
elsewhere):
it as follows:
awesome thanks! I just reset my service required message due to my recent battery change. Saved me a trip to the dealer.
Old Jul 23, 2022 | 11:07 AM
Andy Pearson's Avatar
That was really helpful! Thank you.
I've got a brake pad low error that keeps flashing up. I had the pads checked about 3 weeks ago and had 8mm left, so I'm assuming it's a sensor issue. That error had been doing my head in!
Old Nov 4, 2022 | 12:11 PM
TonyG1966's Avatar
Hi I'm having the same problem on my 2007 XKR and the local garage are ordering in x2 replacement front sensors. Can anyone advise whether fitting requires removal of the bonnet in order to get into the location where the sensors are located? This sounds like a major job to fit something that is of no real value? Better still, what is the downside of disconnecting the things and living happily ever after???
Old Nov 8, 2023 | 12:49 PM
bgpenguin21's Avatar
There's this one;
elsewhere):
it as follows:
First, thanks for posting the Rest Procedure.
Second, in Step #7, can you give me an idea of how long it takes to get from the "resetting" stage to the completed "reset" stage? I just tried going through this procedure a couple of times last night and I was holding the buttons for 2-3 minutes and the message never went to the "service mode reset" stage. Did I really need to hold in the buttons for longer than 3 minutes, or is it maybe something else?
I appreciate the help.
Old Nov 8, 2023 | 06:12 PM
Cee Jay's Avatar
You have to keep the beat! It should go to Reset seconds after the task completion.
It's best to practice a few times, then do a steady one-second cadence. You'll get it, keep trying.
Old Nov 9, 2023 | 01:34 AM
guy's Avatar
guy
Do download the workshop manual and review the procedure. Can’t imagine removing the bonnet when you can easily put it up into service mode (or whatever that’s called)
AbyJag
Mar 4, 2017 10:24 AM
johns427
Nov 8, 2014 10:24 AM
His_Nibbs
Jan 4, 2011 04:43 PM
Oldengineer
49
Oct 22, 2010 01:50 PM
