Climate Control Unit XK 4.2 2007
Old Jun 19, 2015 | 05:36 AM
aldente's Avatar
Default Climate Control Unit XK 4.2 2007
Hello everybody!
Does anyone know, how to get to the climate control unit module? The climate system on my 2007 XK doesn't work anymore since yesterday - just from one start to another. No failure informations on the display. Blower doesn't work, no cold air, no warm air. Fuses and the blower relay are ok, so I presume it could be the climate control module.
Many thanks for any advice!
Old Jun 19, 2015 | 07:04 AM
WhiteXKR's Avatar
Do not attempt major repairs immediately, it could be a computer module crash. Give it a few hours. If it does not come back on its own, disconnect the battery for a minute at the negative terminal, and then reconnect it and see if the functionality returns. Note that you will need to reset the windows per the owner's manual, and recycle the parking brake after the battery disconnection.
Old Jun 19, 2015 | 07:27 AM
aldente's Avatar
Thanks! Will try it this way and give you feedback...
Old Jun 22, 2015 | 12:33 AM
aldente's Avatar
Even after disconnecting the battery , it still does not work :-(
Old Jun 22, 2015 | 05:31 PM
flyc2c's Avatar
Did you try charging the battery?
Old Jun 23, 2015 | 03:36 AM
aldente's Avatar
Thanks for your reply!
No, the battery voltage is actually unremarkable. Is there any reason to charge the battery in this case?
Wolfi...
Old Jun 27, 2015 | 12:48 PM
flyc2c's Avatar
These cars are extremely sensitive to voltage. Search "battery" in this forum and you'll get dozens of hits. Can't count how many times my screen would stay with the leaper on a cold morning only to work fine on the second start after being run a while.
Try it.
Old Jun 27, 2015 | 01:55 PM
MoscowLeaper's Avatar
It may be a blower control module. If it is possible to change a temp. settings on a control panel, but the blower doesn't work - it is it. Usually it may be repaired by replacing a transistor. It is located near a blower behind a glove box in a heater assy.
Old Jun 28, 2015 | 01:17 AM
sov211's Avatar
And if the AC unit has a significant amount of water in it (plug drain tubes) then the unit can be damaged.
Old Jun 28, 2015 | 05:22 AM
aldente's Avatar
Hi fellow members! Thank you very much for your support and help! I think I'll follow the advice of MoscowLeaper as it is possible to change the temp settings on the CP - only the blower doesn't work. Will try to change it next weekend - will keep you on the loop :-)
Old Jun 30, 2015 | 08:30 AM
FrickenJag's Avatar
Former Sponsor
Keep in mind, the condensation tube can cause water to back up into the blower motor. Water may have built up in the motor and caused the blower motor itself to fail.
I noticed this myself when tracking down dripping. I removed the motor and noticed water built up in it.
Easy removal, only 3 torx bolts hold it in place. Just be careful not to burn yourself on the hot under dash light.
Regards,
Derek Fricke
Old Jul 1, 2015 | 04:58 AM
aldente's Avatar
Thank's Derek, will keep an eye on it when doing the job this weekend!
All the best,
Wolfgang
___________________
2007 XK 4.2
1999 XKR
Old Jul 8, 2015 | 02:33 PM
07XKJaguar's Avatar
It's the blower motor module. It will usually get it way before the blower motor if the a/c drain is plugged. I've replaced mine 3 times before it received an extra drain.
Old Jan 12, 2018 | 12:33 PM
Hustle Hyde's Avatar
I am too having this same issue with my xkr. How do you drain the water?
Old Jan 12, 2018 | 12:43 PM
Sean W's Avatar
Can you elaborate? Do you have water at the blower module or are your controls not working as the OP originally posted?
Old Jan 12, 2018 | 03:48 PM
Ranchero50's Avatar
There's a couple different ways. The coat hanger method works if you drop the trans far enough to access the drain. Guys snip the end as well so the pinch seal can't.
Tons of threads on here, some even have pictures. Look and enjoy.
Old Jan 16, 2018 | 08:58 PM
I had water at floor of passenger side.Then a few days later none of the fans are blowing. The controls show up on the screen tho. So I ordered this
Amazon Amazon
I get this item tomorrow and will attempt to put it in. I just got this car a couple weeks ago. 2007 xkr
Old Jan 17, 2018 | 03:05 PM
Sean W's Avatar
EDIT: See Ranchero's response belowVVVVVVVVV
Old Jan 17, 2018 | 03:15 PM
Ranchero50's Avatar
I picked up the $8 one from ebay for the ranger rover and it worked perfectly. Link is in by build thread.
SCMike
Sep 22, 2015 07:34 PM
texaspete
Sep 10, 2015 08:34 AM
ferraripete
Sep 10, 2015 01:24 AM
SCMike
Sep 9, 2015 09:30 AM
tberg
Sep 7, 2015 07:32 AM
