Conv. rr qtr trm sliding panel questions..
Old May 10, 2017 | 07:32 PM
qcktvr's Avatar
Default Conv. rr qtr trm sliding panel questions..
Hello again,
I have some more questions for those that have gone before..
My roof now goes up and down again, but the LHS/drivers side sliding plastic piece is staying forward, it was wedged but now slides freely and springs forward, the cord to pull it back was hanging on the top frame and still has the a loop on the front but it has pulled out of the air damper / spring cylinder.
So, it looks as if the quarter trim panel will have to come out to get at things.
I purchased a pdf manual and understand that the bright Jaguar trim has to be removed from the door scuff plate and discarded!! If careful can it be reused?
I found a 2016 post that Steve / WhiteXKR mentioned and have the part ##s for the repair kit, there are LH/RH ###s, what is the Jaguar protocol for LH, is it the even number?? (C2P21070SEP)?
I suspect that I could find a way to repair the thing once I see it, but to be safe I will buy the repair kit and have it available when I pull it apart.
These jobs always seem a bit intimidating the first time and any advice / tips will be appreciated..
Last question; Is there a good source / dealer in the US that will mail parts? I am going to be in SC in 2 weeks and would like to compare price with the local, 2hrs, dealer here in ON.
Many thanks
Old May 10, 2017 | 07:48 PM
Stuart S's Avatar
I suggest that you contact the Forum sponsors that sell parts, as most provide discounts for Forum members. Hopefully, they'll be able to obtain that kit and have it delivered to South Carolina before you arrive.
Old May 10, 2017 | 09:03 PM
qcktvr's Avatar
Hi, will be hoping to fix the existing part before buying that repair kit as seeing prices around $200(USf) ouch; part like this likely costs Jaguar $20! (and I may not need it).
C2P21071XXX is coming up as the LH part.
And the plastic part will likely have faded and the new one will be yet another shade of??
Any advice for removing that door sill scuff plate, ***-u-me it really has to come off?
Will let you know how it goes..
Old May 10, 2017 | 09:23 PM
JBzXJ40's Avatar
Is this the piece of trim you're referring to?
Old May 11, 2017 | 07:06 AM
qcktvr's Avatar
Yes, that's the piece. The fasteners are all hidden, I believe under the bright "Jaguar" emblem that my manual says is held on with adhesive... (and to discard?)
So easy to damage stuff when poking and prying, trying to figure out how...
Still thinking about it; 2 more cars to change wheels over, and the yard work...
Old May 11, 2017 | 05:41 PM
JBzXJ40's Avatar
Below is what Topix says to remove these 2 pieces of trim, and if I remember correctly, they are separate from each other.
Remove the scuff plate trim panel.
    REMOVAL AND INSTALLATION
    Loading...
    Removal
    1. Remove and discard the scuff plate decal.
      1. Remove the front scuff plate trim panel.
        Hope this helps
        Old May 11, 2017 | 08:40 PM
        qcktvr's Avatar
        Thank You, fingers crossed, looks like the piece with the decal may not need to come off; hope to get that quarter trim panel out over the week end.
        Spent years of my life making interior trim so know how fragile it can be...
        Old May 19, 2017 | 09:43 AM
        qcktvr's Avatar
        Default Conv. sliding panel - fixed - $0..
        Hi again,
        a quick update, all is fixed and working fine again without having to part with any $$$, so me is very happy.
        Thanks to all for pictures and hand holding...
        I predict that unless the design was updated, which is unlikely, then a high percentage of convertibles will suffer from failures in this sliding panel; it is a very poor design. When the top is down, which is how ours spends most of the summer, there is way too much stress on the cord that pulls the panel to the rear, hindsight I should have shortened the spring,(reduced the preload) in the cylinder under the panel.. The "pull" is also to one side, which aggravates the chance of the pins leaving their tracks..
        Should have taken pictures, sorry..
        My cord had pulled out of the small cylinder and the panel stayed fwd.
        With the 1/4 trm pnl out the cylinders were removed.
        The tracks were not broken.
        2 snap hooks hold the end cap on, released with a small screwdriver, LOTS of preload on the spring!
        Piston remained in the bottom, made a wire hook and pulled it out.
        Embarrassed to say, but could not see how the cord had been attached; looked at the longer cylinder but quite different.. (maybe lost a piece??)
        Pondered for awhile, then drilled 2 1/16in through piston in the flat areas under the 'O' ring, made a loop with some soft steel locking wire to hold the loop on the cord, used a piece of wire insulation on it to make it more friendly to the string..
        The piston has a very small bleed hole, they call it a damper, and this fix will have increased the air flow, but the stroke is so short and the top frame going up speed is so slow that in my opinion any dampng is just about meaningless..
        Anyway, it is all back together and working fine.. for now
        Now to think about why the drivers door does not lock..
        Old May 19, 2017 | 11:44 AM
        kj07xk's Avatar
        Congrats!
        Did you have to remove the 'scuff plate' to get the 1/4 trim panel out?
        How did that go, did you have to 'discard' any decal?
        Old May 19, 2017 | 06:40 PM
        qcktvr's Avatar
        No, only the int coloured piece has to come off. There is a squarish cover over the torx screw at the back end, mine was hanging off and easy to remove, now it is back in correctly it will be way more difficult to remove without damaging the panel, but it is way down out of sight, I *** u me someone was in there before. The clips pop out easily. The actual 1/4 trim also released very easily from its 4 clips. Both seat backs are joined and come out together.
        Not something to be afraid of for sure, I think the top going up would just push it forward without the other spring cylinder and a piece of elastic hooked to the top frame would pull it back to the top down position, the Jaguar design is a bit wackey imho...
        Old Apr 28, 2018 | 11:27 AM
        jwooky's Avatar
        Can anyone recommend a place to get these?
        C2P21070LEG
        C2P21071LEG
        Old Apr 28, 2018 | 12:09 PM
        qcktvr's Avatar
        No, I expect you have searched, there are suppliers around... They are molded in colour, so after 11 yrs our originals have likely changed some...
        Have you had a look to see if you really need a new one(s)? My repair cost $0..
        Good luck
        Old May 2, 2018 | 02:10 PM
        jwooky's Avatar
        I have repaired them a couple times already. The little ears on the sliders are pretty warn and they get jammed often.
        Others have found them for ~$50, i keep finding them for ~200
        Old Aug 2, 2018 | 09:55 AM
        fritzthecat's Avatar
        Default Ya just gotta laugh...
        I just had to post this - it's from the X150Service manual I found. I think this is the section that deals with that trim panel. That's a 4000 page service manual that has EVERYTHING about these cars...
        except this.
        Old Aug 2, 2018 | 10:56 AM
        Ranchero50's Avatar
        Actually it's missing quite a few things that I've looked up. Linked paragraphs not existing etc.
        Old Aug 2, 2018 | 06:44 PM
        u102768's Avatar
        except this.
        It is in the manual for the later cars so you could refer to that instead.
        Old Aug 13, 2018 | 08:35 AM
        Default Found one!
        After a couple of hours of on-line searching, I found ONE site that even showed the part:
        https://www.sngbarratt.com/us/#!/Eng...IBLE-PORTFOLIO
        You have to navigate down through the various levels of break-out drawings, first to:
        * Interior Trim and Linings ->
        * Quarter Casings ->
        * Quarter Casing Rear Convertible Portfolio
        and it is part #10.
        All the other sites I checked, and there were about a dozen, when I got to that picture, the cover plate part wasn't shown. This place lists it for about $220. I found one on ebay after searching for the C2P21070 number, but it was tan and in Italy.
        I'm going to try a little harder to make the one I have work before I dump 220 bucks...
        Old Aug 13, 2018 | 02:21 PM
        WhiteXKR's Avatar
        Default Service Bulletin
        Jaguar has a useful TSB on repairing the sliders, including all part numbers. I have attached the document.
        File Type: pdf
        Old Mar 25, 2022 | 11:19 AM
        Klaus0401's Avatar
        This was the file I searched for. Thank you very much.
        Old Apr 25, 2022 | 12:54 PM
        Gator8's Avatar
        Sorry if I’ve overlooked this, but how does one reattach the string to the panel? I can see it goes through the white cylinder.
