Convertible Top Window
Old Jul 10, 2017 | 12:19 PM
slb07jagxk's Avatar
Default Convertible Top Window
My glass back window is falling in, coming unglued from the top.
Any body had/having same issue?
Repair?
Old Jul 10, 2017 | 12:58 PM
Cee Jay's Avatar
Dozens of posts in here, search the forum. You'll be sure to find several.
Old Jul 10, 2017 | 01:02 PM
Cee Jay's Avatar
https://www.jaguarforums.com/forum/s...archid=6725518
Old Jul 13, 2017 | 02:35 PM
jwooky's Avatar
link not working
Old Jul 13, 2017 | 07:11 PM
Cee Jay's Avatar
search "convertible top window" in the "search this forum" thing at the top of the X150 forum page
Old Jun 10, 2023 | 08:06 AM
letsgoblue67's Avatar
I am inexperienced on Forums - how did you manage to repair this?? I have same problem. Thanks.
Old Jun 10, 2023 | 05:44 PM
Stuart S's Avatar
At the top of this Forum's first page are helpful "Sticky Threads". Click on the last one - "How To / DIY Repairs and Maintenance", scroll down to 3. Convertible Top, click it and read the entire thread before you attempt to do the repair.
There are several ways to do it. I recommend using Rhino Glue and Suck 'N Clamps because my repair is still holding.
Good luck!
Stuart
Old Jun 11, 2023 | 12:08 PM
Default Loose Window in Convert
Thanks - I'll try the Rhino glue fix. Appreciate it.
Old Jun 11, 2023 | 01:19 PM
jagjoe's Avatar
I used this method 4 yrs ago and it is still OK.
Old Nov 11, 2023 | 09:00 AM
Default XK Convertible Window Separation Repair
Many thanks to Stuart S for saving my bacon with thorough and detailed instructions on repair. Sorry it's taken a while to respond, I used Rhino Glue GEL instead of the regular glue and it worked just fine. Be careful on selection of Suction-Clamps - I bought Blue ones and they were junk - had a dickens of a time obtaining return/refund on eBay. See the pictures attached - the first three (3) are of damaged top - right side and top side. I decided to look on YouTube and found a Mustang convert top repair that closely matched my damaged area and used Rhino Glue with suction-clamps. There are several good vids on Convertible Top Repair you should check out. The last three (3) pics are the repair: 1-Starting on Right Side of rear window ONLY - do this first, 2- Top of window with all six (6) clamps and 3- had to lightly Open the Top as the closed tension too much to permit good clamping. The Rhino glue ran a bit but is easily removed completely with a Razor Scraper for windows. Let each gluing event dry overnight before proceeding to remove clamps. Thanks again Stuart.
Bill Howard - Brevard NC
badicedog
Jul 21, 2023 09:49 PM
carlprs
Aug 3, 2022 09:31 AM
Todd Wiens
Aug 26, 2021 03:53 PM
vgbrocklebank
Jun 17, 2020 07:06 AM
ed duffy
Nov 12, 2019 03:10 PM
