CTEK 3300 Battery Charger Installation
Old Dec 5, 2017 | 05:32 PM
  #321
Ozmag's Avatar
Brain Johnson is a Geordie, not an Aussie
Old Dec 5, 2017 | 06:16 PM
  #322
Cee Jay's Avatar
Ha! "Brain" Johnson....... that's funny
Old Dec 25, 2017 | 11:41 PM
  #323
dcmackintosh's Avatar
I admit that I haven't been through all 17 pages, but the installation couldn't have been easier on my 2013 XKR-S. I needed only a 10mm socket with extension and used existing nuts on the positive battery clamp and the bracket that holds the DVD changer to the trunk floor. I used a multimeter to check that there was zero resistance between the negative battery post and the bracket, so I'm fairly confident that it's an adequate ground. I then used a zip tie around the suspension cross-brace to provide strain relief for the pigtail, and I can have the connecter either above or below the shelf (not shown) that covers the spare tire (if I had one) well. I do also have the CTEK extension cable. The car will unfortunately mostly be parked in my garage for the rest of the winter here. I should be able to find time in to install my Eurotoys upper pulley, though.
Old Dec 26, 2017 | 03:30 AM
  #324
Stuart S's Avatar
Originally Posted by dcmackintosh
... I can have the connecter either above or below the shelf (not shown) that covers the spare tire (if I had one) ...
If you want a spare tire: https://www.jaguarforums.com/forum/x...-brakes-67260/
Old Dec 26, 2017 | 08:14 AM
  #325
richzak's Avatar
[QUOTE=dcmackintosh;1814695]
Nice clean installation. Good job.
Old Jan 18, 2018 | 11:30 PM
  #326
Gene the Viking's Avatar
this is a fantastic thread thanks. I bought my CTEC and hooked it up to my totally dead battery just to see the results even though I plan on buying a new battery for my 2012 XKR. WOW the car lights started flashing on and off as did the whole dash board and the driver window went part way down. It looked like a UFO. Anyway I disconnected. Is this because my battery is totally dead? Car won't start by the way.
Old Jan 19, 2018 | 07:03 AM
  #327
jagtoes's Avatar
The easy answer is yes. You should get a 10 amp (min). charger and try charging the battery for several hours . It may take the charge so you would be able to start and drive it to get a replacement battery.
Dagny
Jun 11, 2024 01:06 PM
DuhCar
Sep 11, 2015 10:58 AM
speacock
Sep 10, 2015 12:14 AM
DEklof
Sep 8, 2015 05:28 PM
mcdutch
Sep 4, 2015 03:38 AM
