CTEK 3300 Battery Charger Installation
Old Feb 20, 2014 | 09:13 PM
  #101
hdavidson's Avatar
Originally Posted by richzak
After driving either my Porsche or Jaguar XKR, I immediately plug them into the CTEK once I get out of the car.
It takes about 20 minutes or less to get the Green indicator light. It is pretty quick.
If I pop the trunk or even open the door, there is a drain on the battery immediately and the CTEK 3300 changes from Green to Amber instantly to start the re-charge. That's how sensitive these chargers are.
Have you noticed this with your CTEK's?
yes. just look at it funny and it turns amber...
Old Feb 20, 2014 | 09:40 PM
  #102
bocatrip's Avatar
The second I pop my hatch the CTEK goes to amber. I've also noticed that after the car has been on green for days I have managed to see it on amber for a few minutes proving that there is a drain and the CTEK picks up on it and starts the charging cycle until fully charged again. What a smart charger!
Old Feb 22, 2014 | 04:19 PM
  #103
hdavidson's Avatar
I installed the convenience connector in my trunk this after. The location makes it real easy reach and it doesn't obstruct the luggage area. A very easy install... took all of 5 mins.
Attached Thumbnails CTEK 3300 Battery Charger Installation-img_20140222_122522.jpg   CTEK 3300 Battery Charger Installation-img_20140222_160019.jpg
Old Feb 22, 2014 | 04:32 PM
  #104
amcdonal86's Avatar
Very nice, clean install. Did you have to cut the carpet?
Old Feb 22, 2014 | 05:06 PM
  #105
hdavidson's Avatar
Yes, I cut from behind using an x acto knife. The material in very easy to cut through and the CTEK connector comes with a template.
Old Feb 22, 2014 | 09:32 PM
  #106
richzak's Avatar
Very nice, thanks for the post informing all interested in the CTEK products and photos. Well done.
Old Mar 3, 2014 | 07:15 PM
  #107
ShadyJC's Avatar
Originally Posted by BillyD
he said they are M6*1.5, my 10mm socket fits them perfectly.
I can't find the M6x1.5 nuts anywhere - tried several auto parts stores, a specialty bolt store and my local Lowes and HD.
I can confirm that the post on the 2012 XKR is not a 3/16, 1/4 or a M6x1.0
Anybody have any other suggestions?
Old Mar 3, 2014 | 08:12 PM
  #108
Lothar52's Avatar
I have been using the gripper cables instead of the eyelets without any problems. Not as convenient but whatever. Both the XKR and XKR-S were charged up the last few days.
I noticed the 2013 XKR-S stayed green alot longer then the 2012 XKR..wonder why the XKR seemed to have more flipping back and forth from orange to green to orange to green????
Old Mar 3, 2014 | 08:13 PM
  #109
bocatrip's Avatar
I went to my local Jaguar dealership last weekend and noticed their brand new 2014 XKR on the showroom floor had an extension chord running into the trunk. The salesman told me that most of their showroom cars are on chargers regularly. I wonder if they tell potential customers about it or what answer they give when questioned about the wire coming out of the trunk!
Old Mar 3, 2014 | 08:40 PM
  #110
amcdonal86's Avatar
I would imagine putting showroom cars on battery maintainers is not unusual, even among other brands. All that door opening and such!
Old Mar 3, 2014 | 09:55 PM
  #111
hendercc's Avatar
They tell them it's a plug-in hybrid and add $10k to MSRP!
Old Mar 3, 2014 | 10:44 PM
  #112
bocatrip's Avatar
Good Point. Why didn't I think of that?
Old Mar 4, 2014 | 02:39 AM
  #113
Ngarara's Avatar
Old Mar 4, 2014 | 03:59 AM
  #114
BillyD's Avatar
Default M6x1.5 nuts
If you can't find the correct nuts I describe,ie M6*1.5 (6mm * 1.5 thread) you could always purchase new bolts and nuts to fit.
Old Mar 4, 2014 | 01:45 PM
  #115
JustNiz's Avatar
I just got some M6 nuts and 2 regular and 2 lock washers from Home Depot. It fit perfectly.
Old Mar 5, 2014 | 11:02 AM
  #116
ShadyJC's Avatar
Finally, my saga with this has ended. For anyone who is thinking of doing this but might be having trouble finding the right size nut (like me) to thread onto that post, my final solution was this - I cut a section out of the "O" ringlet and made it into a "U". Then I was able to loosen the nut that clamps the battery down and just slipped in the U-ringlet and tightened it back up.
For what it's worth, in my search for the right nut, I stopped at my local dealer yesterday and talked to the shop manager. A few things came out of that conversation.
(1) They don't have that nut or know what size it is
(2) The battery maintainer is a very smart idea - when I told him what I was doing, he knowingly nodded in my direction and told me that I would come to "appreciate that".
(3) He told me that mounting the ground (black) ringlet directly onto the battery post was not recommended. At least on my 2012, I guess there is a battery monitor or something on the ground wire? You can see it on the left hand side of the picture from intdiamond's post #53 in this thread. His exact words were that it make the monitor "unhappy". And then he said, "if you follow the ground cable from the battery you can easily find another grounding point away from the monitor". So I did, about 10 inches away under the carpet there is a screw that the battery ground goes to, so that's where I mounted the ground U-ringlet. Again, loosen, slip in and tighten back up.
I finished up the install yesterday with the CTEK comfort indicator panel mounted into the side of the trunk, and I was "green" this morning!
Thanks for everyone sharing their experiences and knowledge on this topic.
Old Mar 5, 2014 | 03:25 PM
  #117
amcdonal86's Avatar
Why is it that few people seem to be wiring these devices using the remote battery terminals?
Old Mar 5, 2014 | 03:35 PM
  #118
Knomad's Avatar
I wired mine to the remote terminals. It was a lot less trouble than what some people seem to be having. The only thing I had to do was to crimp on larger O-ring lugs to the charger cable in order to have it fit the terminals. It's worked fine so far this winter.
Old Mar 6, 2014 | 07:44 AM
  #119
Lothar52's Avatar
WHERE IS THIS BLACK REMOTE TERMINAL/NUT...I CAN NOT FIND IT!?! Can you take a picture of where it is at for me!?!?! Thanks
Lothar
Old Mar 6, 2014 | 03:20 PM
  #120
Ngarara's Avatar
It's in the spare wheel well, on the left.
