disabling engine from running - fault code?
Old Mar 22, 2025 | 11:00 AM
bill_jags's Avatar
Default disabling engine from running - fault code?
2007 xk 4.2 NA. When I complete my rebuild of the oil cooler, I want to disable the engine from starting until oil can start circulating. Owners manual identifies the fuse as 33, 30 amp back seat panel. If I pull the fuse to allow oil to refill the circuit, will it generate error codes? Is there a better way to achieve this? I noticed that the xk8 forum stated that flooring the accelerator prevents running, on those engines. Thanks in advance.
Old Mar 22, 2025 | 11:21 AM
Cee Jay's Avatar
There is something much easier, but I don't recall the full correct procedure. Something about depressing the accelerator pedal numerous times and holding it to WOT and then cranking the engine.
Maybe someone else can elaborate this.
Old Mar 22, 2025 | 11:53 AM
JagV8's Avatar
Just holding the pedal fully down (check no obstacles under pedal!) before trying to start should do it. Don't pump it.
Old Mar 22, 2025 | 12:18 PM
jahummer's Avatar
I'd just pull the fuel pump fuse. But I'm not certain this's even necessary as there will still be friction even without ignition.
Old Mar 26, 2025 | 05:43 PM
bill_jags's Avatar
Pulled the fuel pump fuse, 33 (30 amp) rear fuse panel, which DID NOT generate fault/error codes when cranking to circulate oil thru the replaced oil cooler. Thanks for the replys.
jetpilot1
Mar 13, 2024 04:47 PM
MauriceB
May 20, 2020 05:25 PM
Arne Riis
Feb 13, 2019 05:38 PM
walkman1
Apr 23, 2016 12:00 PM
billm
Mar 21, 2015 08:46 AM
