Do I need to use fuel additive in XKR
Old Sep 8, 2014 | 04:21 PM
texasxkr's Avatar
Question Do I need to use fuel additive in XKR
I just turned 1000 miles on my 2013 XKR coupe that I purchased in May. The car is fantastic and gives me a thrill every time I drive it. I drive the car when weather permits and where I know I can park it without worry. I leave the car hooked up to my CTEK 3300 charger to keep the battery ready.
My question is do I need to treat the fuel between drives?
Old Sep 8, 2014 | 05:38 PM
plums's Avatar
If you run through at least a tankful every couple of months and don't let it sit idle for more than a month ... then probably not.
Jandreu's Avatar
Well other than just showing off your in the wrong fourm however I would think no additive is needed.
Old Sep 8, 2014 | 06:10 PM
TreVoRTasmin's Avatar
If you were closer I would say that you need a co-driver not fuel additive but as was stated so long as you're replacing the fuel every 2-3 months you should be good. I also wouldn't leave it too empty for long periods as it allows more moisture to go to town on the inside of the tank.
Old Sep 8, 2014 | 06:16 PM
texasxkr's Avatar
Thanks, I just now realized that I posted in wrong forum, but thanks anyway. Senior moment!
Old Sep 8, 2014 | 06:17 PM
DaveInVA's Avatar
Sorry about hijacking the thread but I see you have a TVR. I owned this 1980 2500M for many years and really enjoyed it.
Dave
Old Sep 8, 2014 | 07:39 PM
Moved to correct forum for you
Old Sep 8, 2014 | 08:13 PM
Mikey's Avatar
Even the much hated E10 fuel is good for six months and there's no additive that's proven to be required or to do much.
Old Sep 8, 2014 | 10:44 PM
plums's Avatar
six months would be too long whether or not ethanol is involved, but especially if ethanol is involved.
six months is the same as putting it away for the winter in which case the precautions taken should be the same.
there are additives with proven track records for specific purposes such as cleaning injectors on older cars or stablising fuel for storage.
they just aren't required for the purpose stated in the original post.
Old Sep 9, 2014 | 08:51 AM
Rahtok's Avatar
Naw, no need for any sort of treatment. I tend to stick to Tier 1 fuel producers myself, just because it's relatively convenient and overall a good idea. The ECU will adjust for lower octane fuel if you feed it that, but you lose HP if you don't feed it premium -- and it's actually noticeable. <cough> Yes, I did go through a tank of 87 just to see.
Old Sep 9, 2014 | 09:05 AM
jagtoes's Avatar
I have always run a bottle of Techron through once a year with every car I have. I also run a few bottles of dry gas to reduce or eliminate some of the water build up . Cheap investment .
toronadomike
Jan 22, 2026 10:13 PM
dsnyder586
Dec 29, 2024 07:39 PM
mrplow58
Jan 21, 2024 05:53 AM
buickfunnycar.com
Oct 19, 2015 07:21 PM
deanh
Sep 6, 2015 08:20 PM
