Trying to find the correct left side door handle bezel. I did the eBay thing however it is incorrect and to small. If you know someone that might be sitting on the proper part I would appreciate it.
Tim
Try the Forum sponsors who sell parts and the recyclers (junkyards) such as Pacific Motors. Find the correct part number by searching online OEM Jaguar parts vendors and reviewing the parts diagrams.
I have talked with quite a few already, dirty secret is the recyclers evidently pull the expensive parts and then crush what is left. After I posted this is found a supplier in the UK, hopefully he can help me out, but hope someone here on the forum parting one out will have what I need.
Tim
No seriously, where's the issue. I did a google search and they are everywhere unless this isn't what you're referring to. Can you post a pic from the other side? I think some of the XF's share that part as well
The eBay XK items are non passive entry, the others are for different models and do not fit. I need one for passive entry, approximately 1/4 inch thicker. UK connection appears promising.
According to the part numbers posted I purchased the correct one, but it is not a proper fit as it is not flush with the door handle which I know is not correct.
I will add the part was in a Jaguar factory, but did not save the bag to confirm pat number, but the eBay history shows correct part number. Could be an innocent mistake on part of seller, as I did not remove from bag until paint, just checked it against the handle without actual mounting, this could be on me as well. Thank you GGG, for confirmation of part number.
My last 2007 XK was non-passive and my current 2014 is passive. I hadn't realised there was a difference in the bezels until I read your post and then checked JEPC.
As a follow up to this mess.
When I ordered the bezel I did not know there are two different sizes, I got luck and ordered the correct one, but all we can figure is the non passive is what I received and again, I did not know to check. Hopefully the correct one will arrive on the 10Th. Thank you Graham for your time to post,for confirmation, the part numbers.
Tim
