Drivers side window problem
Old Jan 21, 2024 | 11:16 AM
markva44's Avatar
Default Drivers side window problem
When I get out of my car in my garage I have the drivers door window open to make it easier to get out the car, I press the lock button for a couple of seconds then the window closes. Before I get into the car when its in my garage I global unlock to open both windows, to make it easier to get into the car.
Today I tried to global close the drivers door window but it would not work. Both windows open with global but only the passenger side closes. Vey odd as its been working fine up until today. The window works with the switch except 1 touch does not work on the drivers side door window.
Any ideas please
Old Jan 21, 2024 | 11:48 AM
Stuart S's Avatar
First, reset both windows.
Window reset procedure
If that doesn't make a difference, do it again. If no change, your battery may be weak. How old is your battery? Is your car garaged or parked outside? Cold weather is a battery killer, regardless of age. In the morning, before starting your car, your battery should measure at least 12.6 volts. If it's lower, it's weak and should be recharged or replaced . If you don't have a voltmeter, your local auto parts store probably will load test your battery for free.
Good luck!
Old Jan 21, 2024 | 07:56 PM
steve_k_xk's Avatar
Could also try a hard reset of the battery , I always have this issue with drivers window everytime I disconnect my battery to perform work
Old Jan 22, 2024 | 04:53 AM
markva44's Avatar
Hi. The car is used as a second car, its always garaged with a C-Teck charger on. I tried a reset but the instructions were not th same as the link you put up. Ill try the reset again today and report back. Thanks for taking time to reply.
Old Jan 22, 2024 | 11:23 AM
markva44's Avatar
Strangely today when i got into the car the global lock and unlock operated both windows perfectly.
BlueSmudge
Aug 14, 2021 11:17 AM
powerlord
Oct 21, 2016 07:14 AM
tomtomterrific
Jun 4, 2011 06:45 PM
RichmondXK
May 22, 2011 12:06 PM
Skid Mark
Sep 3, 2010 09:54 PM
