The Duckbill, updated status on this issue
Old Dec 17, 2023 | 11:04 PM
Tracee's Avatar
Another photo from the interior. Cyan circle. Planning on using this locator to approach the issue in the Spring-time.
Old Dec 18, 2023 | 07:20 AM
kj07xk's Avatar
Remember, the other side of the firewall appears differently, as that duckbill hole is in an enclosed area, and you access the duckbill from a hole below it. See the line drawing in post #7 in this thread:
https://www.jaguarforums.com/forum/x...ve-box-167968/
Old Dec 18, 2023 | 02:21 PM
XKDreams's Avatar
Originally Posted by McJag222
What a crappy idea and application that duck bill was.
It wouldn’t take a rocket scientist to conclude that the duckbill would clog over time. I do appreciate the effort to keep bugs out…but really how’d they think that would weep water consistently over time?BTW…do all XK model years have this issue? Or did they correct it in the later years?
Rep
Does the attached photo accurately represent the design used in 2010+ models? Does this solve the problem? Are there other issues with bugs crawling up into the ac on these?\
Old Dec 18, 2023 | 02:42 PM
kj07xk's Avatar
Hmmm, an idea just hit me, wish I’d thought of it while I still had an intact duckbill (although slicing it off was probably a better solution anyway).
Find something hollow and flat enough to fit between the transmission housing and firewall, with a hole to match up over the duckbill hole, add some foam weather strip around the hole, slide it in to cover the hole, and connect a shop vac to an open end on this doohickey, and suck air though the duckbill to clear it out. Eh, just a thought.
Old Dec 20, 2023 | 10:09 AM
Cee Jay's Avatar
Drill a small hole in the bottom center area of heater box, shove a Borescope Camera through the hole and maneuver it to the duckie and push it through. Withdraw the scope and speedtape the hole. DONE.
Old Sep 23, 2024 | 09:34 AM
UsmaXKR2010's Avatar
Cee Jay - we have the same model and it seems there is no way to get at the duckbill from the top side with the supercharger in place. Your approach seems to be the easiest DIY solution. Can you assist me by providing a photo of where you drilled your hole? Any other tips would be appreciated. Such as directional indicators to find the duckbill or length of bore scope needed. Thanks!
Old Sep 23, 2024 | 10:18 AM
Cee Jay's Avatar
I never had the problem and haven't repaired mine. I referenced another thread in this forum where someone else did exactly what I stated. It's been many years since I saw that thread and I don't know who wrote it, when, or the name of that thread.
Sorry, man.
I'm quite positive the hole was near center at the lowest spot in the heater box though.
Old Sep 23, 2024 | 10:39 AM
  #28
No Quarter's Avatar
It is possible to get to the duckbill from above with supercharger still installed. As described. It does require non-bodybuilder arms, your's or a friend's.
Brake buster
Feb 1, 2015 03:26 PM
JimC64
40
Dec 22, 2012 03:34 PM
JimC64
Sep 10, 2009 12:44 PM
KA3AX
Oct 22, 2008 05:21 PM
