Early xkr ,Where does the end of this pipe go.
Pulled my bonnet/hood today to check oil and noticed a small black pipe (blue arrow) running horizontally along the front frame of the car ,just above the fan. As you can see from the pictures there's a plastic type cylinder to the right of the rad.(red arrow) The small pipe goes into the top of this and runs along the front frame, but to where. Think it has to push into something, any ideas. Can someone pull their hood and see, thanks.
And another point , this last few days on start up there is a whining nose from my drivers side engine bay. This sound seems to be coming from down behind where the air filter is, in that direction. It does it for about half a minute then stops , not sudden but like a fan slowing down. It a noise that i would say is between a fan/hoover.
I've had a hunt through the workshop manual, and I can't identify it, but there's a lot to look at and we don't know what system it's part of. Not much point looking at my car, sorry, because it's a 5.0 (and, anyway, it's dark outside...).
Mine is an '07 XKR as well but I don't have the pipe or that cylinder on mine although it is a Japanese import. There is a bracket which I suspect your cylinder is attached to and there is a bolt hole on the cross beam but I don't have whatever those bits are.
I had to remove the engine cover to take the photo so that may be why you aren't getting much help.
It looks like some kind of vacuum canister but don't know what for. Maybe for the headlight washers to pop up .
Think I've found it: the 'tank' is the secondary air injector vacuum reservoir. Here's what the SAI system does:
The reservoir sits between the intake manifold and the SAI switching valve, with a one-way valve to keep the vacuum from being lost when the intake manifold is not at low pressure. It ensures there is always a source of vacuum to operate the SAI control valve, even when the throttle is closed and there's no vacuum in the intake.
So, that reservoir should have a connection to the inlet manifold, and another to the SAI switching valve. It's hard to tell from the diagram, but i think the pipe that runs along the frame is the one that should connect to the inlet manifold.
Secondary Air Injection (SAI) is fitted to the vehicle to reduce exhaust emissions to meet European Union (EU) Stage 4 and Federal Petrol Emission standards. The SAI system comprises:
• SAI pump
• SAI valve
• Associated pipes
• SAI Absolute Pressure (MAP) sensor (NAS only)
The SAI pump is used to provide a supply of air into the exhaust manifolds during the cold start period of the engine. The SAI cycle lasts for up to 65 seconds. The hot unburnt fuel particles leaving the combustion chamber mix with the air injected into the exhaust manifolds and immediately combust.
• SAI pump
• SAI valve
• Associated pipes
Also, a good reason to determine where that pipe terminates, is for engine engine performance. A vac leak in an engine can cause for performance woes.
A vac leak in a aspirated engine makes them difficult to tune, the idle is not steady etc.
Happy hunting.....
Happy hunting.....
Yes, if the outlet pipe from the reservoir is open, then the manifold can suck outside air via the reservoir. Also, with the SAI system not working, you'll get more smoke on startup, and the cat converters won't heat to operating temperature as quickly.
I can't see where the hell that connection goes to - most of the other vacuum pipes go to the induction elbow connector, which is the tube between the throttle body and the supercharger, so that would be somewhere to look.
The front of the car is on the right of the pic. The pipe comes from right to left and connects just below the flexi pipe,then the other one emerges and connects to the device in the bottom rh of pic.
Hope that helps
Hope that helps
I replaced the SAI on my daughters BMW recently. Not sure if this is the same as yours but when it was failing it would make a whining noise. Made the engine sound like it had a jet turbine starting up when cold. It lasted for about 40secs then switches off. Its all to do with the emission control system. When it finally fails it will light up the engine check light. I wondered if it was disconnected on purpose because it too was failing??
I remember seeing this vacuum reservoir thingy on a later model S-Type R and wondering what the hell it was.
Now I know.
If that hose is not connected then you will have a vacuum leak which is making that noise I guess, unless someone disconnected it on purpose and plugged the fitting.
Now I know.
The switching valve has two vacuum connectors - i think the upper one (closest to the electrical connector) goes to the control valve, and the lower one to the vacuum reservoir.
aholbro1
Dec 29, 2024 06:46 PM
