Enhance Stock Microphone
Old Mar 15, 2013 | 01:34 PM
J3Langford's Avatar
Default Enhance Stock Microphone
Is there anything that can be done to improve the stock microphone?
Old Mar 15, 2013 | 02:18 PM
CleverName's Avatar
Subscribed -
One of my higher priority projects this summer. I need to look at the OEM setup to see what can be done in the allocated space because I have several mikes from lapel to professional floating around my basement.
Anything has to be better that the OEM one...
Vince
Old Mar 15, 2013 | 02:43 PM
WhiteXKR's Avatar
I have installed of a couple of these electrets with aftermarket JVC headunits with Bluetooth in XK8s with very good results: Omnidirectional Mono Microphone
Old Mar 15, 2013 | 02:58 PM
J3Langford's Avatar
It uses a standard microphone jack?
Old Mar 15, 2013 | 03:00 PM
J3Langford's Avatar
I wonder if there is a software tweak for it.
Old Mar 15, 2013 | 03:20 PM
WhiteXKR's Avatar
No, I cut off the jack and wired the mike directly in to replace the crap ones inside the JVC headunit.
Old Mar 15, 2013 | 06:28 PM
u102768's Avatar
There was a TSB issued about a replacement microphone + updated software (see attached)
"Cause: This is a combination of microphone positioning and noise cancellation/signal processing within the phone system software."
Old Mar 15, 2013 | 06:56 PM
JgaXkr's Avatar
That bulletin is for the X150 not the X100 steel bodied cars.
Old Mar 15, 2013 | 09:21 PM
u102768's Avatar
Not unusual on an X150 forum and the OP has a 2007 XK
Old Mar 15, 2013 | 09:57 PM
JgaXkr's Avatar
sorry about that as I was so interested in a solution for my car I failed to notice which forum this was.
hoodun
Feb 20, 2023 05:52 AM
Johnken
Apr 8, 2018 10:21 AM
Johncy2000
Oct 2, 2015 01:05 AM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
