F Type Carbon Ceramic brakes on XKR
Old Apr 20, 2019 | 09:11 AM
pauledddy's Avatar
Default F Type Carbon Ceramic brakes on XKR
Hi Guys,
Come across a listing of F Type CC brakes, with discs, calipers and the rear hubs for sale. What is needed to get them into the XKR?
Thanks in advanced!
Old Apr 20, 2019 | 11:28 AM
MarkyUK's Avatar
Paul what are you getting them for?
A) weight saving
B) Improved braking performance
C) A bit of both
I may be wrong but it should be a straight bolt on replacement as I had Wortec discs designed for the F Type fitted to my XKR. They used the same calipers and gave me a weight saving greater than the CC discs & pads, cost fitted was £2.5k
I might be wrong but the actual caliper/carrier will be steel, only the pad itself is ceramic and there are quite a few ceramic pads out there.
I may be tempted to to upgrade my standard calipers (2 pot at front and single at rear) in a few years, but for now am happy with the improved braking performance and minimum dust from fitting EBC red
May be worthwhile speaking to a local Indy and check what their install costs would be, in the meantime here's a pic of my wortec's fitted
Old Apr 20, 2019 | 11:34 AM
pauledddy's Avatar
A) weight saving
C) A bit of both
I've PM'd you the link to the set up mate
Old Apr 20, 2019 | 12:22 PM
badicedog's Avatar
A) weight saving
C) A bit of both
very nice setup. I too saw the F type carbon ceramic brakes. Wondering if they will fit my 2009 XK? Been looking to upgrade my brakes with either Alcon or XKR brakes...
Old Apr 20, 2019 | 01:25 PM
Stuart S's Avatar
Retrofitting OEM Alcon 6-piston front and 4-piston rear calipers and crescent-grooved rotors, electronic parking brake and related brackets etc., can be done but it's very expensive even if you can find all those parts used. I recommend that you save your money and put that cost towards either a 2008 XKR Portfolio, which included as standard equipment the Alcon Performance Brake package, or a 2009 XKR Portfolio that has the $5,000 optional APB package.
See: https://www.jaguarforums.com/forum/x...estion-169753/
Old Apr 20, 2019 | 01:30 PM
pauledddy's Avatar
I have a 2010 XKR, I didn't fancy the 4.2. It's lowered, and had some cosmetic bits to make it my own. Which is why I asked if it was doable. If I wanted a 2008/2009 XKR I would've looked at getting one in the first place.
Old Apr 20, 2019 | 02:12 PM
Stuart S's Avatar
Anything is doable if you have enough money. Whether it makes sense is another matter.
You need to create a signature that includes your model year and any other information that can help Forum members reply to your questions. How was I to know that you have a 5.0L XKR and aren't interested in a 4.2L? Alcons were never available for the 5.0L models.
Old Apr 20, 2019 | 02:24 PM
pauledddy's Avatar
I apologise, I thought I said year in the original post!
Sorry mate
Old Apr 20, 2019 | 03:10 PM
Stuart S's Avatar
No problem, we're human and make misteaks.
Old Apr 22, 2019 | 08:59 AM
110reef's Avatar
Mmmmmm. Steak....
Old Apr 24, 2019 | 10:53 AM
XJ8JR's Avatar
I'd be interested in fitting the carbon ceramic calipers just for looks. They may work fine but I think the floating style calipers just look cheap.
mlebofsky
Jun 3, 2020 06:03 AM
Stwsam
Jan 14, 2018 03:27 PM
Benz2Jaguar
Aug 19, 2015 09:23 PM
SoCalJagS
Mar 7, 2015 01:55 PM
Unhingd
Jan 12, 2015 06:22 PM
