Fasteners for XKR 4.2L Engine Cover C2P5448
Old May 31, 2020 | 05:48 AM
  #41
Cambo's Avatar
Just to give an update, the Land Rover screw PZM100060 is a couple of mm shorter than the original screw on the engine cover, but it works fine and the head of the screw looks identical to the original.
So it's an alternative. I put one on a car today.
Didn't try for the rubber grommet though.
Old Jun 2, 2020 | 03:43 PM
  #42
miles61's Avatar
I found this on Ebay and it fit,my 07 XKR engine cover. https://www.ebay.com/itm/254509097895
Old Jun 2, 2020 | 05:24 PM
  #43
Cee Jay's Avatar
ONE SCREW for seven bucks??!!?? Yeah, 'screw' that noise.
Old Jun 3, 2020 | 11:26 AM
  #44
lon1's Avatar
Thank you, I ordered 1 today.
Old Aug 20, 2021 | 05:31 PM
  #45
rickjensen's Avatar
Default Engine Cover Screws
Still have some? I need one. Thanks
Old Dec 28, 2021 | 09:23 PM
  #46
Deabs's Avatar
Default Land Rover PZM100060
The quarter turn fasteners from Land Rover work fine. They are only about 1mm shorter but they are shorter.
The shorter length can be overcome by pressing the receptacle clamp so that it is closer to valve cover bracket. The receptacles can be easily slide off to remove and simply pressed in vise. I
I also added nylon washers to each in order to retain the fasteners from getting lost in the future. Found 1/4 inch nylon flat washers at home improvement store. Just press them on to shaft. Oh...the only difference is the Land Rover fastener is a standard driver head not the phillips head.
Improvise - Adapt - Overcome
Old Jan 21, 2022 | 09:40 AM
  #47
Budster's Avatar
Default Clips for cabin filter cover
Originally Posted by asb
The fasteners that TexasTraveler linked to above are the ones I recently used on my 5.0. I can confirm that they fit perfectly. I assume they'll work on the 4.2 as well. You just have to line them up with the holes and push. They go in without a problem.
I have a 2010 5.0. Will these also work for the cabin filter cover plate?
Old Apr 29, 2024 | 06:16 AM
  #48
Matusco's Avatar
Jaguar XK XKR Engine cover grommets I can get them for you or just order on eBay these are Land Rover but all the same fitment..
OzDave
Detailing / Car care
Oct 16, 2019 08:15 AM
Russ9898
Jul 26, 2019 12:31 PM
NICKGTD40
Mar 12, 2017 08:04 PM
powerhouse
Sep 18, 2015 11:12 AM
