Finally fitted 20mm spacers all round
Old May 10, 2015 | 03:02 PM
Milu's Avatar
Default Finally fitted 20mm spacers all round
As title.
After the troubles I had trying to fit 15 mm I went for it with 20mm.
However,anyone else think its a bit much on the rear with standard alloys?
They're flush with the body and slightly shielded by the plastic spats but I'm not sure if 15mm would be more subtle. I still have the 15 but would need to do a few mods to use em.
Oh also fitted a new spoilerName:  a6ea42a42493af3ec1fb6c71f0e9e87e.jpg
Size:  927.4 KBName:  28e6416aa05c60c8ed148ae38f2f65e5.jpg
Size:  949.2 KBName:  edeaa7709395d9021a0aaabc0a748115.jpg
Size:  955.5 KBName:  93e1b60e0e65c01afc064401359ddc51.jpg
Old May 10, 2015 | 03:19 PM
mcdutch's Avatar
I hope you won't sandblast the paint on the side of the car.
How is road behavior affected by the spacers?
Old May 10, 2015 | 04:05 PM
Milu's Avatar
Good point regarding paint!!
I've not been far yet but everything seems fine. From past experience I would say the steering feels a bit slower with spacers.
It's hard to separate real changes from imagined ones. A blind test would be better but of course impossible when you mod your own car.
Old May 10, 2015 | 08:51 PM
sherbercars's Avatar
How come you had a problem to install the 15mm , I have just installed them with 20" sentas and lowerd HR springs with no problems The only thing I had to do was cut off the non threaded ends on the studs,.
Old May 11, 2015 | 12:01 AM
Milu's Avatar
Don't know what the situation is with other sentas but mine foul on the nuts that hold the 15mm spacers on. It's only a couple of mm but I would have to grind the wheel a bit.
Old May 11, 2015 | 06:54 AM
kj07xk's Avatar
Originally Posted by Milu
...but I would have to grind the wheel a bit.
Instead of grinding the wheel, sherbercars was saying that you cut off a bit (the non-threaded part) of the OEM stud.
Old May 11, 2015 | 09:26 AM
Correct. If you look at the back of the wheel after you mounted & dis mounted you will see where the ends of the studs ( bolts ) that hold the spacer on, have scored the inside of the wheel , just cut off the end of the stud , it is just there to help guide the wheel on into place .
Old May 11, 2015 | 02:15 PM
Milu's Avatar
You misunderstand guys. Mine don't foul on the studs but actually the nuts. Weird I know but it's the case!
aholbro1
Dec 29, 2024 06:46 PM
H20boy
Dec 24, 2024 03:23 PM
smith356
Oct 7, 2015 06:41 PM
al_roethlisberger
Sep 11, 2015 10:04 PM
metalmarty
Sep 11, 2015 07:05 AM
