Find the coolant Leak (not a game)
Old Oct 24, 2024 | 03:11 PM
wymjym's Avatar
Default Find the coolant Leak (not a game)
Well, my 2008 xk base (non SC) sprung a leak last week. I ‘knew’ it was the valley hose, @ 2 quarts of coolant puked onto my garage floor after returning from a trip to town. I couldn’t see any leak from up top and underneath the rear under tray was damp and dripping.
Several days later I pulled the intake manifold and low and behold the valley hose was not leaking (but is soft and squishy).
I added some fluid to the reservoir…no leaks…I pressurized the tank to 14 psi and held it at that pressure for @ 30 sec…no leak. I pulled the under engine pan…there was no signs of coolant. The oil pan does have several drops around its circumference but nothing major. I cannot find any tell-tale trails flowing down the engine block, nothing appears wet…running my hands around all hoses does not lead me anywhere.
Where to look next?
wj
Old Oct 24, 2024 | 03:15 PM
guy's Avatar
guy
Give it a proper pressure test.
Old Oct 24, 2024 | 04:11 PM
Cee Jay's Avatar
I thought my valley hoses were leaking but they were not. It was the oil cooler.
Old Oct 24, 2024 | 04:59 PM
kj07xk's Avatar
Agree, 30 seconds isn’t long enough. If the pressure doesn’t appear to drop, leave it on longer, even overnight (I’ve done that).
Old Oct 25, 2024 | 01:37 PM
trkyam's Avatar
you may need to run the pressure test with a hot engine to show the leaks.
Old Oct 25, 2024 | 02:27 PM
RichardS's Avatar
Is that possible? Firstly. you can't remove the expansion tank cap with the engine hot and, secondly, as the temperature drops the pressure will drop and you will have to re-pressurise it until the system is at ambient temperature which is back where we started.
Richard
Old Oct 25, 2024 | 03:29 PM
Cee Jay's Avatar
Get a pressure test cap kit.
I don't know if this one fits, it's just an example:
Amazon Pressure Test Kit for Automotive Coolant Amazon Pressure Test Kit for Automotive Coolant
Old Oct 25, 2024 | 04:31 PM
wymjym's Avatar
I guess I might need to purchase that tester, thanks for the linkage.
I have crawled around the underside after holding my handheld tested on the tank for 4 minutes (constant pressure from compressor) earlier today, there were no changes, no leaking fluid. Using another approach I added a schrader valve to an old reservoir cap and tried to pump it up, I couldn't build any pressure!
I can see one (1) drop of coolant located above the oil cooler on the base of the engine block. There is a very slight area behind the crank pulley that appears as if it was damp but ever so slightly. I recall that my last oil change 4k miles ago I did have several drops of coolant on the oil cooler. The oil cooler hoses are dry and the cooler only had a couple of drops on it when I dropped the underpans the other day. I guess the question is, could the water pump seal be going out and when the engine was warm it finally burped a bit?
Placing my fingers against the block in that area does not reveal any fluid or moisture, none of the hoses have any signs of fluid ever leaking. I'm asking a friend to stop by and eye ball it.
Since the car has almost 120 k on it I'm inclined to rip it apart a but further tomorrow, anticipating a water pump or thermostat housing issue. If nothing shows itself I'll get the 'real' tester ordered and go from there.
If I hadn't made my valley hose assumption I probably would have already determined the issue since I could bring it up to operating temps.
Life goes on
wj
Old Oct 25, 2024 | 04:34 PM
McJag222's Avatar
I think you could be on the right track with the water pump
Old Oct 25, 2024 | 04:55 PM
trkyam's Avatar
Water pump or oil cooler pipe behind water pump
or outlet pipe.
Yes you can hook up a pressure test cap then warm
The engine up which may reveal leaks which a cold engine
does not.
Old Oct 25, 2024 | 05:58 PM
wymjym's Avatar
or outlet pipe.
does not.
No intake!
wj
Old Oct 25, 2024 | 07:05 PM
trkyam's Avatar
Touché
Old Oct 28, 2024 | 07:04 AM
fritzthecat's Avatar
A few years back I did this with an old reservoir cap to find a leak in a Ford Escape:
Turn the regulator on the air compressor down to zero, plug the air hose on the cap, and then sloooooowly turn up the regulator until you have 5 or 10 PSI. Hard for a leak to hide under those conditions. Most coolant pressure caps blow at about 16 PSI, so I wouldn’t go any higher than that with the air.
Old Oct 28, 2024 | 10:08 AM
wymjym's Avatar
currently removing hoses, saw a slight damp spot behind crank pulley...
my previous testing included:
Ken D
May 10, 2024 03:28 PM
miami jags
Nov 24, 2022 03:09 PM
mit2700
Jul 27, 2019 11:10 AM
jam1white
Jun 10, 2014 09:56 AM
hafferf
Sep 11, 2011 02:01 PM
